B21 custom hydraulic thumb, using B26 factory option parts?
   / B21 custom hydraulic thumb, using B26 factory option parts? #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Have a B21. Never had a thumb option I know of so I purchased a mechanical bolt on thumb from Bro-Tek couple years ago. Works well enough, but, it is a manual thumb and so I have to curl the bucket to it. As the design is such the thumb cannot move any more forward and still stow properly, I often find I have to curl the bucket too far for convenient grabbing of the target. That's just how it is.
So, contemplating rigging it up as a hydraulic thumb which almost forces me to relocate the pivot of the thumb to where most hydraulics seem to be. Sharing the bucket pivot point. Unless I mistake the pictures I have seen. Main obstacle is modifying the thumb to have "ears" or something to fit around the bucket and finding/making longer pins to go through and allow proper greasing. making the mount points and lugs for the cylinder eyes seems just a bit of fun and frustration. But the pins present a bigger problem for me, not having a real machine shop or even a suitable metal lathe.
In a flash of (possible) brilliant insight I recall the B26 is very similar even using all the same 3pt hitch stuff. The B26 does have a "factory" hydraulic thump option. That got me to thinking I could just buy the pins, grease fittings and bushings from Kubota and go from there.
While I suspect the lengths and diameters of the pins would work on my existing buckets, I'd like to be more confident before plunking down even small change (as these things go). A hundred or so is still a hundred or so, especially if it is thrown down a hole.
Anyone know for sure? I can post part number, if needed, but, won't unless asked.
Thanks in advance.
   / B21 custom hydraulic thumb, using B26 factory option parts? #2
Looking at parts diagrams from Messicks would give you insight into design and part differences. Was a thumb an option for the B21? That would be your best choice. Kubota and other manufacturers are not good about sharing between models.
Never operated a manual thumb. Only problem with a hydraulic thumb is once you use one is hard to do without.
B26 backhoe quick attach is the best system I have ever used.
Never an option for B21 that I know of. I did look over the B26 parts list but there are no measurements, that I could decipher. Like I said, I could order the pins to find out, but seems wasteful at this point, when someone might actually know.
Is the bucket a quick attach also? The B21 is not.
   / B21 custom hydraulic thumb, using B26 factory option parts? #4
Quick attach buckets is an option. Works well with the hydraulic thumb. My B26 came that way with three buckets so didn’t have to figure anything out.
Quick search found a couple after market thumbs for the B21. Considerations on weld on or bolt on for stick strength.
Tend to think a weld on lug for the cylinder pivot would be best. The stick has more steel further up and I can weld in a plate or two if needed.
I found a post/thread on this subject that may pretty much cover all the issues.
Caterpillar 60in Pallet Fork and Frame Attachment (A49461)
Caterpillar 60in...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
TEST BID LOT (A50775)
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
Unused Delta Crash...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
