B21 "clunk"/jerk when starting forward or reverse motion
   / B21 "clunk"/jerk when starting forward or reverse motion #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Several times now have experienced a "pop/clunk" and a bit of a "jerk" when starting out and just rolling slowly. Could be my imagination, or being on gravel, but is seems a bit "bumpy" too. It only does it occasionally, not constantly or consistent with any particular motion, but, maybe when turning a bit.
Cannot see any coincident motion in what I can see of the steering mechanism from the seat and, of course, cannot see the drive shaft, as I call it, which is what I suspect/hope it may be. Reasons being, cost aside, the sound is not muffled at all, the "boot" on the shaft was torn for a while before I noticed it, operating in dirt and gravel. When I changed fluid and filters not long ago and it was clean, no metal at all and it was clean.
Once it does that once or twice, I can get on with what I am doing and it seems fine, but, I worry that I am creating a bigger problem by not dealing with it now.
Any advice?
Did not notice fluid was low, due to a leaky cylinder I forgot about.
After topping it up, it seems better all around.
   / B21 "clunk"/jerk when starting forward or reverse motion #3
Check all fasteners securing wheels to machine. Lug nuts but some designs have the wheel center secured to the wheel rim
Dave M7040
UNUSED FUTURE 90B HAND-HELD TROWEL (A57193)
UNUSED FUTURE 90B...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
2025 Poly Fuel Tank with Electric Pump (A55852)
2025 Poly Fuel...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
