Backhoe B21 backhoe stuck on tractor
   / B21 backhoe stuck on tractor #11
Make sure that the weight of the hoe is not causing the pins to bind, use the bucket on the ground to carefully position the latches so they are centered around the pins. Can you disassemble the latches to release the hoe from the tractor? Mushrooming the various latch components with a hammer is not helpful. Once the hoe is off, completely disassemble the latches. Clean all dirt and rust off everything with a wire wheel. File or grind all mushrooming to resemble original shape. Coat everything with anti-seize, and reassemble.
Thanks again! I have decided to stick to the lube and wait strategy for at least one week. I drilled a 5 mm hole through each bush and injects oil under pressure there twice a day. Uses an oversized wrench trying to move the thing as the mount lever is far too weak for anything close to what is needed for some action. If I am not successful maybe I will probably adopt the submission strategy by JayC accepting that some things just wonエt come loose. But doing what SixHoeBob suggests is tempting... its a question of showing the damned machine who is in charge! I will let you know!
Lars
Still lubing and waiting... But I could not help trying a trick today that moved the pivot on one side. I squeezed a big wrench from under the tractor around the bush taking support on the lever poiting upwards. Then I connected the end of the wrech shaft with a chain under the tractor to the FEL. Curling the FEL really moved the mount lever enough to release the mechanism. I can not tell what really moved or if I also bent the axis. I am not sure about that so I will give the other side a litte more time for lubing. Strangely enough I can not get the lever to move in the opposite direction even with help from the FEL (chain connected to the base of the mount lever, then inside the rear wheel and under the FEL-subframe). But this technique seems more adequate than the hammering... at least for my knuckles! So much for patience! To be contnued.
Lars
   / B21 backhoe stuck on tractor #14
Not offering any personal advice from experience here but
Anybody try drilling and inserting grease zerks to keep things from rusting/fusing in place?
   / B21 backhoe stuck on tractor #15
Something dawned on me- I keep my B21 under cover (not outside) so the levers don't get water on them. I suspect between that and shooting a little lube in whenever I lube the backhoe or loader I've been OK. If I kept it outside I'd probably want to lube it more often and push the lever back and forth a few times to help work in the lube.
Grease zerks sound like a good idea, and if you parked your B21 outside grease would be better in the weather than a lighter lubricant. I don't know if the sleeve is thick enough for a zerk though.
When building our house, the B21 was outside on site for about 5 months. I got more paint fade and rust from that time that it got in the 8 years before that when it was under cover.
kubotaswede, I hope it works out for you :)
Pete
   / B21 backhoe stuck on tractor #16
I bought my B26 with a bit over 300 hours and had an interesting time getting the BH off the first time. A bit of penetrating oil and some muscle did the trick though. I sure wouldn't have wanted to wait till it had thousands of hours or I'd still be wacking at the pins.
I remove the BH and install a snow blower every fall so the problem of stuck pins has now gone away. Lots of grease or anti-seize compound on the pins in the spring is the way to go.
BTW: Whenever I take any pin or bolt off I smear lots of anti-seize on before I re-install it, you never know when you'll have to get that pin or bolt off again. Seems like cheap insurance, especially as things gets older and rustier, the equipment that is, not the operator! :laughing:
Good luck!
   / B21 backhoe stuck on tractor #17
I doubt it is necessary, but surely couldn't hurt. Knowing now that they stick, if I ever get a chance to get them apart, or if I get a new one, I will slather the pins with some BelRay grease - that'll keep them submissive for many years.
JayC
   / B21 backhoe stuck on tractor #18
I do the same. I learned that lesson from 15 years of riding dirtbikes and working on my kid's sh*tbox cars. I virtually never install an untreated (dry) fastener - it goes on with grease, anti-seize, or loctite - whichever is most appropriate.
I also never install a bolt/nut without correctly torquing it, but that's another ugly story.
JayC
Well, waiting and lubing doesnt seem to do the trick... I managed to release the pin set device used to lock the holder mounts on both sides by the chain trick I described earlier in the thread, even an iron bar used as a 5 ft lever does nothing on the ... thing! Maybe the BH never was off the tractor? Now I am thinking of removing the rear wheels to get access to the mainframe pins on which the holder mount grips when locked. The plan is to hammer them out. That would release the BH. Anyone tried that trick? With the BH off the tractor I think there will be much more room to deal permanently with the problem. Or should I just look at the BH as a permanent part of my tractor?? Is it worth while seeking professonal help? And I mean a workshop not mental! There must be some folks out there who had the same problem with a B 21. Sugestions appreciated!
Thanks Lars
Sorry, I missed when editing this post. It is the holder mounts that locks the BH on the tractor that are the issues now... Seems to be permanently stuck!
Lars
10 ft Shipping Container (A55973)
10 ft Shipping...
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
Ford 8340 (A53317)
Ford 8340 (A53317)
2014 FOREST RIVER WILDWOOD RV TRAILER (A58214)
2014 FOREST RIVER...
2018 KENWORTH T800 HOTOILER (A58214)
2018 KENWORTH T800...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
