Backhoe B21 backhoe bucket - slow/weak curl
   / B21 backhoe bucket - slow/weak curl
Well, maybe some operators need to be better trained. Need to talk to his boss . . .
It did seem to be weaker to me than last I used it
I checked, out of the blue, the BH/3Pt selector, seems it was not fully into the BH position. I had recently had the BH off for box blade work, and thought I had set it properly. But, there it is.
It now appears stronger and, while it is not a beast at stump pulling, I did mange to dig out a fair sized white pine, with the last minute or two spend just "rocking" it till it gave up. It did "stall" a few times, but taking a smaller bite seemed to be the ticket there. I presume it is normal to start smelling hot oil when working hard, but started taking it a bit easier, just in case.
So fairly confident now there are no seals leaking as there are no discernible noises or vibrations in the cylinders at limits.
   / B21 backhoe bucket - slow/weak curl #12
Digging out stumps is about the hardest work for any backhoe. It's hard even on a full sized hoe.
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
UNUSED JCT 96" PUSHER BLADE (A57193)
UNUSED JCT 96"...
2023 JOHN DEERE 26G EXCAVATOR (A52707)
2023 JOHN DEERE...
SCAN TO RECEIVE TEXT UPDATES (A57192)
SCAN TO RECEIVE...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
