B20 vs B8200?
/ B20 vs B8200? #1
Aggie_Tractor_Guy
Both have around 600 hours, both have FEL, both cost same at around 6000. The 8200 is older, but looks solid. The B20 looks good too. Which one would be best for light tilling, pulling a small disc and flailing? I know tha b20 is commercial, but will it work for doing some farm work? I have approximately 5 acres with vineyard and some filberts.
/ B20 vs B8200? #2
Welcome to the forum. I can help a bit on the B20 with a few facts. You are correct that the B20 was more of a commercial model normally sold with a backhoe. The B20 was made until 1996 when it was replaced with the B21. With only 600 hours on a 10+ year old commercial tractor I would be wondering how accurate the hours are. These were very solid tractors yet had a few draw backs for your application. They ran larger hydraulic pumps than other tractors of similar size because of their intended backhoe use. That used up much of the potential PTO horsepower making them less desirable for mowing and tilling. Also the loader can not be removed from the B20 as it can be from many tractors. That could be a problem working in your vineyard.
Sorry, I don’t know much about the B8200. Hopefully someone else can share some facts on it.
MarkV
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
F-150 4WD (A63689)
F-150 4WD (A63689)
213324 (A64279)
213324 (A64279)
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
2008 STOUGHTON ZGPVW-535T-SC-AR 53X102 T/A DRY VAN TRAILER (A59914)
2008 STOUGHTON...
