B20 Loose 3 PT Lever
   / B20 Loose 3 PT Lever #1
Anonymous Poster
Epic Contributor
I am selling my B20 and want to make sure it is in the best tip-top shape. One thing to adjust--- The lever for the 3 point will not hold position-- just drops to the bottom. I have used the stop pins, but I know this should not be, because it used to work fine. I did pick up a set of concave spring washers that are meant to hold tension on the lever ($3.00). Dealer said these sometime get "flat" and need to be replaced. I took off the lock nut , but for the life of me cannot get the lever to come off the shaft. I even have a dealer spec drawing that shows how it goes together, and it really should just slid off so i can put the new spring washers in place. Have used liquid wrench and elbow grease, but do not want to break the shaft that leads into the control box. Any thought or suggestions?
   / B20 Loose 3 PT Lever #2
Sometimes a little heat from an oxy/accel torch works wonders! /w3tcompact/icons/smile.gif
Just wanted to here that from a pro, before trying myself. I give ot a try and let you know.
   / B20 Loose 3 PT Lever #4
Tried the heat, wouldn't budge. Kubota wins on this one, dealer job.
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
Yard Machines Tiller (A55973)
Yard Machines...
Forklift Safety Basket Attachment (A56857)
Forklift Safety...
2017 INTERNATIONAL 4300 21FT BOX TRUCK (A57880)
2017 INTERNATIONAL...
2017 Bobcat T450 Compact Track Loader Skid Steer (A56857)
2017 Bobcat T450...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
