B20 Loose 3 PT Lever
   / B20 Loose 3 PT Lever #1
Anonymous Poster
Epic Contributor
I am selling my B20 and want to make sure it is in the best tip-top shape. One thing to adjust--- The lever for the 3 point will not hold position-- just drops to the bottom. I have used the stop pins, but I know this should not be, because it used to work fine. I did pick up a set of concave spring washers that are meant to hold tension on the lever ($3.00). Dealer said these sometime get "flat" and need to be replaced. I took off the lock nut , but for the life of me cannot get the lever to come off the shaft. I even have a dealer spec drawing that shows how it goes together, and it really should just slid off so i can put the new spring washers in place. Have used liquid wrench and elbow grease, but do not want to break the shaft that leads into the control box. Any thought or suggestions?
   / B20 Loose 3 PT Lever #2
Sometimes a little heat from an oxy/accel torch works wonders! /w3tcompact/icons/smile.gif
Just wanted to here that from a pro, before trying myself. I give ot a try and let you know.
   / B20 Loose 3 PT Lever #4
Tried the heat, wouldn't budge. Kubota wins on this one, dealer job.
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52128)
2022 New Holland...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
DMI 13' Chisel Plow (A50515)
DMI 13' Chisel...
