B1750HST year?
   / B1750HST year? #1
Andyfr
Scottish Highlands, UK
Kubota B2150HSDB 4WD
I have been offered a B1750HST with less than 600hours but the owner - who bought it from a dealer - doesn't know what year it is. I have had a look on Tractortips.com but can't find a relevant one. I was wondering if anyone could tell me what year it is. The serial number is 61933 and the engine number is D2501727870. Also, what FEL does this model use, is it the same as the B2150?
The tractor is over 550 miles away so not easy for me to go and look at it.
Thanks in advance.
   / B1750HST year? #2
Andy,
I don't have the docs to decode the serial # here @ home, but my wild guess would say 1993-1995...
If it has an OEM loader, it's probably an LA300A... but could be a B1640A ... both are quick-attack loaders.
LA300A
Lift height: 70.7"
Clearance dumped: 52.2"
Reach at max height: 23.4"
Reach on ground: 45.0"
Max dump angle: 45deg
Rollback angle: 25deg
Digging depth: 4.0"
Height in carry position: 43.5"
Bucket width: 48"
Lift capacity at full height: 660lbs
breakout force: 1150lbs
Raising time to full height: 2.6 sec.
Lowering time/power down without load: 1.9 sec.
Rollback time: 1.8 sec.
Dumping time: 1.6 sec.
B1640A
Lift height: 69"
Clearance dumped: 53"
Reach at max height: 19"
Reach on ground: 43"
Max dump angle: 42deg
Rollback angle: 22deg
Digging depth: 9"
Height in carry position: 46"
Bucket width: 42"
Lift capacity at full height: 600lbs
breakout force: 970lbs
Raising time to full height: 3.6 sec.
Lowering time/power down without load: 4.6 sec.
Rollback time: 2.05 sec.
Dumping time: 1.98 sec.
B2150 took the LA350A.
HTH...
   / B1750HST year? #3
Your tractor comes out to a 1990 by the numbers you have provided. It would be within the last 200 built for the year.
   / B1750HST year? #4
Art,
Do you know when the first year of product for the LA300 was? For some reason, I'm thinking it wasn't manufactured in 1990...
   / B1750HST year?
Thanks Art and Muhammad. I thought it might be about that age. It doesn't have a loader with it but I saw one for a B2150 for sale which is why I wanted to know if it would fit. I may have to pass on the tractor if I can't find a FEL for it.
Regards
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A54757)
UNUSED IRANCH SEMI...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
