B1750HSD steam from valve cover
   / B1750HSD steam from valve cover #11
I changed the oil 3 years ago
:ashamed::ashamed::ashamed:
   / B1750HSD steam from valve cover #12
slan,
Here is whats happening. Every time the barometric pressure goes up and down, the crankcase breathes in and out. Every inhale brings in moisture. Just like outside, when the temperature falls at night, dew forms on the inside of the engine. Some of the water runs down the inside of the block and ends up in the oil. It starts out going to the bottom of the sump because the oil floats on the water. When you start the engine, the water is churned into the oil and distributed all through the engine. The crank, the cam, the cylinder block are all ferrous metal, which means they will rust. Rust on the cylinder wall will etches the surface, which will damage the rings and pistons and lead to excessive blow by and increased oil consumption... Don't you think its time to change the oil?
All good points IBNXE. Yes it was three years ago but only 20 hours ago that I changed the oil. But with it sitting so much I agree it is a strong possibilty that is what is going on. I bought the oil filter yesterday and will be changing the oil this weekend. I'll report back as to any improvement.
   / B1750HSD steam from valve cover #14
slan,
I guess I missed the quote marks. I would never go three years in anything before changing oil because of the points you have made. Sorry Aquetrac, just surprised at the interval. ;)
Oil is cheap compared to internal wear components.
   / B1750HSD steam from valve cover #15
meh...ours have smoked since we got it back in the early 90's. Sitting in the barn all winter oil can gather moisture from condensation. We use ours all winter so it's not as bad as yours...change the oil and take it out for a good exercise and it'll be fine.
   / B1750HSD steam from valve cover #16
Once the oil has gotten up to temp the condensation will evaporate in minutes. If you are still getting steam after an hour of running you have a problem.
So here is an update: I changed the oil and filter, the oil was black but so far I see no water (I saved it in a clear jar to see if it seperates). The oil cap did have a gray almost grease-like residue around it and water droplets. I ran the tractor a full RPM and drove it for thirty minutes. Still steaming and when I hold my finger over the breather tube, pressure builds up. When I release my finger, steam rushes out and so does about a teaspoon of water. I checked the radiator level and it did not appear to go down. I think I've got problems beyond condensation. Is there a pressure test of some sort to determine a blown head gasket or cracked block?
   / B1750HSD steam from valve cover #18
I'd run it a lot longer than that. You have to get the oil hot enough to boil the water out of it, but also evaporate and purge that water vapor out of the system.
I used to work in a lube shop and we could always tell the people who never used their vehicle for anything other than short commutes to work. The oil cap, valve cover innards and dip stick would be covered in "peanut butter". Just let it run.
Yeah, we may be wrong, but I still agree this is a condensation issue.
E
   / B1750HSD steam from valve cover #19
I disagree on the condensation. It appears to way to much moisture for condensation but it will not hurt to run it longer and make sure the oil gets hot.
   / B1750HSD steam from valve cover #20
As per my original reply, I still think there are most likely worn piston rings - possibly due to lack of regular use and pitting of bores. This would explain the pressure build up in breather pipe.
Exhaust gasses are mostly CO2 and water - and it could be this water that condenses inside engine if it is used for short runs that subsequently evapourates out when engine is next used and then reforms water seen by OP.
I also think that for a cracked block or blown head gasket to be cause of the water, it would be coming from coolant and you would see a drop in radiator.
J
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
BUYERS PREMIUM & PAYMENT TERMS (A52141)
BUYERS PREMIUM &...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
John Deere Imatch Quick Hitch (A50514)
John Deere Imatch...
