B Series tool box
/ B Series tool box #1
AJL
South Eastern Ontario
2008 L5240HSTCC, 2007 B3030HSDC, 2008 F3680, 2008 GR2100
Well, after years of being educated and entertained by the contributions of others I finally feel like I have something worth posting. First time with pictures, so I hope this works.
I've been looking for a way to add a tool box on my B3030HSDCC. The stock tool box is inconvenient and ill conceived, and there was no real good place to externally mount a "normal" tool box. I figured the space behind the seat in the cab would be the best place for a small box, and I bought a 30 cal. Ammo can for that purpose. However, before I proceeded with that plan a few pieces in my scrap pile inspired another design.
I drilled two holes in the 3" channel and then drilled corresponding holes in the loader frame which I tapped to allow me to bolt the base to the loader frame. The channel straddles the round tube and creates a level mounting surface. I was resiting the urge to weld this in place and felt two holes were less likely to cause any structural issues with the loader frame then welding it would. Additionally, it's cleaner if I chose to remove the base at some point. I should mention that my tractor is out of warranty, so no real concern about voiding the warranty.
After cutting off the smaller of the two plates of the top piece, which was part of never used piece of exercise equipment, I welded it to the 3" channel. After a couple coats of "chevy orange", I mounted it to the loader frame with Stainless bolts.
Rather than test my ability to weld on the thin metal of the Ammo Box I made use of the existing holes and bolted the box in place. This actually made it easier to bolt the base in plase as well.
The Ammo box got a couple coats for black semi-gloss Tremclad, and was re-mounted and re-purposed.
I haven't had an opportunity to live with in the field, but I'm pretty happy with the results. I only need a few hand tools for installing and removing loader mounted tooth bar and forks, and for replacing shearbolts. The can blocks the view on that side, but no more than the loader valve on the other side. It's pretty solid, and out of harms way. The location doesn't interfere with removing/replacing the side panel of the hood, or the task of removing/installing the loader. I didn't keep track of costs, but it can't be more than $25, and it was a fun project.
But, I can't take all the credit, I did have a couple assistants...:laughing:
AJL
/ B Series tool box #2
Very nice use of space as well fine looking craftsmanship.
Great looking write-up and pix also.
Thanks
/ B Series tool box #4
Nice job :thumbsup:
/ B Series tool box #5
Looks like it was meant to be..nice work. :)
/ B Series tool box #6
I also used a simular ammo box for a tool box but i found room behind the seat I can't believe anyone would build a tractor with out a tool box!!!
/ B Series tool box
Thanks for the compliments. :) These projects are functional and a good reason to get out in the garage and put my brain to work in the winter...plus I'm just learning to weld, so it's good practice.
/ B Series tool box #8
That terrible excuse for a tool box that comes from the factory is just about the only thing I would change on my tractor. I don't get why they would do something so poor on an otherwise very well thought out tractor.
/ B Series tool box #9
Project looks good . I used to have a helper like that .... now she's 16 , it happens before you can beleive it .
/ B Series tool box #10
About the only thing I keep in mine are the extra shear bolts for the snowblower. :(
/ B Series tool box
I think realized that at the time. I actually put the date on that piece she's working on and put it in a safe place. Thought it would be neat thing to have some day in the not too distant future. Nostalgic much?!? :laughing:
I agree that the factory tool box is a joke. But, it is one of my few complaints. Which reminds me. Ductape...I believe you and I have the same seat in our tractors...best money I ever spent. They don't seem to sell that model at TSC or Northen tools anymore. Glad I got mine when did. Oh, I hope I didn't start something ...:p
/ B Series tool box #12
Real nice job!!!!!! Can you get the side panel off and on OK?
/ B Series tool box
Thanks. Yes the panel comes off with it in place. I tested that as I installed, and after. No issues.
I used the 30 Cal. can, partialy because I originally intended it to go behind the seat, and partially becasue that was the only size they had in stock at Princess Auto when I went. However, you could could potentialy use and slightly wider Ammo can and still have room.
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
2015 John Deere 8345RT Track Tractor (A63109)
2015 John Deere...
New/Unused Quick Attach Post Driver (A61166)
New/Unused Quick...
207275 (A52708)
207275 (A52708)
UNUSED WOLVERINE SWDB-11-84W HYD DOZER BLADE (A62131)
UNUSED WOLVERINE...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
