Tires B Series R4 to Turfs Experience
   / B Series R4 to Turfs Experience #1
Dillier23
Illinois
Case IH, Deere, Kubota, Yanmar
Hello again, I'm looking for experiences with the B series tractor from folks that have R4's but changed to turf tires. I seem to damage the lawn somewhat when it's a bit wet in the spring with the R4's that came on my B2620. If you have experience with both on a similar machine can you please let me know if it's worth the $800-$900 to have a set of turf tires to mow with?
   / B Series R4 to Turfs Experience #2
I had a B8200, with loader and rear blade. Turf tires. I could drive it over lawn without damage unless I dug in with 4wd turning, or spun a tire on wet grass. My L3130, which weighs twice as much, with R4s, can't be used on wet grass without leaving tire divots. Not enough tire contact area.
   / B Series R4 to Turfs Experience #3
I run turf tires on my B3030. I had them put on because I figured that I will be going over mainly lawn with the tractor. I also have a BX-25 with R4's, but can't use an obvious side by side comparison.
I would advise you to stay with the R4's. Why spend the money, if you don't have to. And if you need any lawn repairs, you got a tractor to do the repairs, right?
Attached is a shot of what the turf tires on my B3030 did to my lawn during the spring thaw. The tires are loaded with beet juice; I continuously ran over the same spot bringing firewood to my porch.
   / B Series R4 to Turfs Experience #4
Depends on how fussy you are with your lawn! I personally would not spend that money for just my lawn.
I have a B7800 with r-4's. I have a B3200 with turf tires. Both tractors weigh similar, both sets of tires loaded 75%. Both set of tires are very similar in many catagories of traction, ground damage, etc.
I bought the B3200 with turfs because I use it in a mowing business (lawns and bush hogging) so I am on many other peoples lawns and they are fussy when they have to pay for mowing service, however I probably could have gotten away with the r-4's if it came right down to it as I am also on lawns with my B7800 with r-4's and that doesn't tear up much either.
One noticeable difference would be if your lawn had shallow roots/thin canopy and was wet and you spun the tires, then the r-4 gaps would tear more then the titan turfs. but if you are careful about not spinning and take wide turns or 3 point turns, you be ok with the r-4's. If it is not wet , under normal conditions, there is hardly a difference.
I also take it the other way with traction being more important then ground damage, as I use both tractors in the woods in a firewood business. Other then mud, there is not much difference. Of course the r-4's are better then the turfs in the mud.
In the snow, the turfs will get a little better traction over the r-4's with and without tire chains and if you use the plain "ladder" chains, the turfs will get better traction then the r-4's due to the chains falling in the gaps of the r-4's. The turfs will allow much more of the chain to meet/contact the snow/ice/ground.
Other noticeable differences I have experienced are, the turfs will slide/spin in mud more. Also, when bush hogging at night in dew or when wet, the turfs will spin a little sooner and when going downhill, "come out from under you" (slide) sooner then the r-4's. the Kubota B series are one of the lighter tractors per hp and don't put a lot of ground force traction through weight, so that is why I feel there is not much of a difference between the r-4's and the turfs.
Good advice so far. I'm not wanting to spend money just to spend it, just looking for a better ride and don't want the mashed grass under the lugs that tends to not get cut as well as the rest.
I could be too fussy as well.
   / B Series R4 to Turfs Experience #6
If you do much work with the loader you might want to check and make sure that the turfs can handle the same loads.
   / B Series R4 to Turfs Experience #7
Possible to stay off the grass when it is wet and avoid the issue? Luckily you have a Kubota which engineers its tractors on the lighter side partially for this very reason.
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2024 CATERPILLAR 299D3 XE SKID STEER (A51242)
2024 CATERPILLAR...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
