B series fel question.
   / B series fel question. #11
the 2320 has the same loader frame dimensions as the 2620 & 2920 and can use the B3200 pin-on quick attach. I have the pin-on QA and I'm fabricating a SSQA for a couple lightweight skid steer implements. The 2620 & 2920 has more grunt. Not sure how but I think the hydraulic cylinders are a bit larger, giving them the edge in lifting capacity.
   / B series fel question. #12
Look at the loader model. The model number is the lifting capacity in kilograms (so the LA302 on our B7500 can lift 302kg or ~664#).
Aaron Z
   / B series fel question. #13
If you go into thick brush, wire or tape the bucket QA lynch pins. Brush pulled one of my lynch pins out, pivot pin worked out, resulting in a bent bucket support frame which was an expensive repair.
I work in woods much of the time. I replaced QA lynch pins with 6M X 45 metric nuts and bolts.
Thanks! Good safety tip!
   / B series fel question. #14
You can purchase a universal skid steer QA to pin onto your loader arms. When I had a B3030 I bought one online from Hayspear.com
skid steer quick attach adapter to fit front end tractor loader or older skid steer
As noted above, it's going to add some weight as well as place the load a little further out in front of the lift arms - thus decreasing lift capacity. You'd also have to weld a QA plate to your bucket.
I let mine go with the tractor when I traded it. Pretty much had to because the original brackets had to be cut off the bucket to weld a QA plate on. Just something to consider.
   / B series fel question. #15
I built a blade for the follow on my B3030. I used 3*3 square tubing and drilled holes for the pins. I can pop the bucket off and pick up the blade in about 2 minutes. The problem I still have is I cannot angle the blade so it limits my abilities to direct the snow. I will try to upload some photos today.
2018 Ford F-350 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2020 CATERPILLAR 938M WHEEL LOADER (A51242)
2020 CATERPILLAR...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
Hyster H225E (A47384)
2013 ISUZU NPR STAKE BODY TRUCK (A51219)
2013 ISUZU NPR...
