lawn_king
Veteran Member
- Joined
- Jun 17, 2006
- Messages
- 1,622
- Location
- Hanover massachusetts
- Tractor
- kubota L 3540 hsdc,B 2320 hsdc & lots of other stuff!
Can you get standard quick attach on the b series fel buckets? Or should i say b series fels?
I bought a B3200 last year with the Kubota quick attach. I like the Kubota QA, I dropped my bucket in about 30 seconds. Pull two hitch pins then pull the two attachment pins. Lift the loader arms and back away. Works really slick..
If you go into thick brush, wire or tape the bucket QA lynch pins. Brush pulled one of my lynch pins out, pivot pin worked out, resulting in a bent bucket support frame which was an expensive repair.
I work in woods much of the time. I replaced QA lynch pins with 6M X 45 metric nuts and bolts.
