B+S vert, twin 44R677-0021-G12, 24HP Idle issue.
   / B+S vert, twin 44R677-0021-G12, 24HP Idle issue. #1
subby
westbrook CT
sears suburban
My Husky/Craftsman 917.203900 wants to stall at minimal idle speed with a rough idle.
I checked the plug firing with a spark tester, but it has good spark on both cylinders at speed and idle. Apparently the carb idle circuit has a problem, or the mixture adjustment maybe be off. I doubt if the carb needs a rebuild. Before I get into it, I am going to pop the hood and try the idle adjustment and check the fuel bowl for water etc. Nice engine in a questionable mower? The RS 800 CVT Variator requires constant cleaning to keep it functioning. This requires about 3-4 hours as the fuel tank has to be removed to access the CVT. I have installed a temporary fuel tank on the rear of the mower to eliminate constant removal of the fuel tank. Not handsome, but it functions! The original install according to sears manual was to be an under the fender tank, this one came with the under seat tank, a losing preposition!
Thanks,
Subby
   / B+S vert, twin 44R677-0021-G12, 24HP Idle issue. #2
Since you moved the fuel tank, that's the first suspect. Check fuel flow and tank venting.
Poor idle is often due to poor mixture which in turn is due to gum in the jets from gas evaporating in the carb. The idle jet passages, being the smallest, are the most affected. Disassembling and cleaning the carb bowl and jets is usually a first step.
   / B+S vert, twin 44R677-0021-G12, 24HP Idle issue. #3
   / B+S vert, twin 44R677-0021-G12, 24HP Idle issue. #4
Actually for me first step is spraying around the intake gaskets with carb cleaner to check for air leaks.
   / B+S vert, twin 44R677-0021-G12, 24HP Idle issue. #5
Most B & S carbs incorporate an emulsion tube to break up the fuel and mix it with air.
In the B & S world it is called: Carburetor Nozzle 299740
The main jet is unscrewed to access the tube.
Use a flat screw driver that exactly fits the slot in the main jet or you will end up in a big mess.
The holes often need to be poked out with a fine strand of wire. You cannot get it clean without removal!
See photo.
Dave M7040
   / B+S vert, twin 44R677-0021-G12, 24HP Idle issue. #6
No removable emulsion tubes on these. If your fuel supply is good, you can try to drain the crud out by removing the solenoid on the bottom side of the bowl. Beyond that, if you're not experienced with this carb- you may want to have it serviced or simply replace the carb (OEM). You can try removing the shroud, the top cover (3 screws) and finding the two holes that have the brass fuel pipes on them, give them a quick blast of carb spray to clean the mains. Then quickly put the carb cover on and start the engine and run it for minute only to see if there is improvement before you put the shroud on. If not done quickly the cleaner can distort the jets o-ring or the seal below the pick up tube.
   / B+S vert, twin 44R677-0021-G12, 24HP Idle issue. #8
I’d be using Seafoam too.
   / B+S vert, twin 44R677-0021-G12, 24HP Idle issue. #9
I tend to use Seafoam all the time, in every tank of 'crapolene'.......:laughing:
Hi,
The majority of people don't realize how costly a simple lawn mower is in terms of replacement parts. The cost of a new B+S Carburetor for this twin is listed at $197.00 to$220.00. A new engine is $1500.00 list. All similar Koehler's and others are in this same price range 0r more. A 17.5 HP for a MTD is nearly the same. When I was into repair I was going to rebuild a blown Sears engine which I received, the part cost exceeded a complete new engine by $300.00. I had a recent model Ingersoll air compressor for repair, a guy let it run low on oil and kaput! The cost of a new one was about 800 to 1K. Part cost was $800.00, no labor. It is an unfortunate situation as 90% automated machine work on die cast parts! End cost is probably a third or less of the retail price. My son's Big Cadet 2000 had a simple oil leak on the crank, that engine if not repairable would have cost $1500.00. A local shop here is really rip off place for parts, so you have to hunt a reasonable part cost and do your own labor!
2015 Chevrolet Tahoe SUV (A53424)
2015 Chevrolet...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2006 APPA TL (A55787)
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52705)
2019 CATERPILLAR...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A55787)
2025 JMR 78in Dual...
