B&S Engine Starter Replaemnt
/ B&S Engine Starter Replaemnt #1
tophat2432
South Bend, IN
13AI607H088
I am trying to replace a starter on a B&S 22HP motor (mod# 461707 Type 0143E1) on a 2000 Yardman. Bolts for old one are under flywheel and are un-accessible. Need directions or repair manual location.
/ B&S Engine Starter Replaemnt #2
hi top hat... i am working on a 14 hp b/s horizonal right now.. if your motor is horizonal , you are gonna have to pull the flywheel and coils to get to the top starter bolt.. good luck.. c falcon
/ B&S Engine Starter Replaemnt #3
If you turn the flywheel around there should be a spot with a recess that you should be able to get in with a box wrench.
/ B&S Engine Starter Replaemnt #4
The starter bolts of ALL B&S horizontally opposed engines are accessible WITHOUT removing the flywheel as indicated above, provided the bolts are original. I can send you a Service Manual for your engine IF you like. Address below, put in proper format and remind me engine model number and what you want.
Walt Conner
wconner5 at frontier dot com
