B&S 21hp starter
/ B&S 21hp starter #1
Chuck52
Mid-Missouri
Kubota L210
I've got an MTD Yard Machine 46" rider with a 21 hp B&S twin. Worked fine last week, but today the starter spins but doesn't engage. I assume I have a solenoid problem, but the parts lists and manuals I have don't show how to get to the starter. Battery seems OK, showing 12.8V, though not under load. I put it on my charger anyway and it sure spins the starter fast, just no engage. Can anyone tell me how to get to the starter so I can begin my usual method of whacking it (gently) with a screwdriver?
Thanks,
Chuck
/ B&S 21hp starter
Pull the hood and it's on the right side. A little thought got me to that point, and I pried the gear up and it cranked the engine just fine, so it's the solenoid, which is apparently inside the starter. OK. Gotta go get a darn big star type bit to remove the starter, but then I'll read one of the earlier threads about rebuilding B&S starters.
Chuck
/ B&S 21hp starter #3
Chuck
my 18 horse B/s engine was going the same thing, seems the gear that engaes the flywheel is PLASTIC AND THE teeth JUST GOT chewed up
/ B&S 21hp starter
Frank,
Not only is it plastic, but there doesn't seem to be a solenoid. Looks like the gear spins into contact by centrifugal force along a spiral groove in the shaft, and then is disengaged when the starter stops turning, by the flywheel just screwing it back down the shaft with the help of a spring. My plastic gear is fine....probably just needs cleaning the groove in the shaft and lubrication so it travels easy. You should be able to get a replacement fairly cheap. Mine takes a T40 tork bit to remove the starter.
Chuck
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A64553)
2018 Roadtec...
2018 FORD F150 XLT (A65643)
2018 FORD F150 XLT...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
2012 Kenworth T660 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T660...
