B&S 21hp starter
   / B&S 21hp starter #1
Chuck52
Veteran Member
Mid-Missouri
Kubota L210
I've got an MTD Yard Machine 46" rider with a 21 hp B&S twin. Worked fine last week, but today the starter spins but doesn't engage. I assume I have a solenoid problem, but the parts lists and manuals I have don't show how to get to the starter. Battery seems OK, showing 12.8V, though not under load. I put it on my charger anyway and it sure spins the starter fast, just no engage. Can anyone tell me how to get to the starter so I can begin my usual method of whacking it (gently) with a screwdriver?
Thanks,
Chuck
   / B&S 21hp starter
Pull the hood and it's on the right side. A little thought got me to that point, and I pried the gear up and it cranked the engine just fine, so it's the solenoid, which is apparently inside the starter. OK. Gotta go get a darn big star type bit to remove the starter, but then I'll read one of the earlier threads about rebuilding B&S starters.
Chuck
   / B&S 21hp starter #3
Chuck
my 18 horse B/s engine was going the same thing, seems the gear that engaes the flywheel is PLASTIC AND THE teeth JUST GOT chewed up
   / B&S 21hp starter
Frank,
Not only is it plastic, but there doesn't seem to be a solenoid. Looks like the gear spins into contact by centrifugal force along a spiral groove in the shaft, and then is disengaged when the starter stops turning, by the flywheel just screwing it back down the shaft with the help of a spring. My plastic gear is fine....probably just needs cleaning the groove in the shaft and lubrication so it travels easy. You should be able to get a replacement fairly cheap. Mine takes a T40 tork bit to remove the starter.
Chuck
2015 TROXELL 130BBL VACUUM TRAILER (A53843)
2015 TROXELL...
2006 GAYLEAN  130BBL VACUUM TRAILER (A53843)
2006 GAYLEAN...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2019 GENIE GS-1930...
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
