B-7800 hydraulics
/ B-7800 hydraulics #1
BlacknTan
Platinum Member
Adirondacks of NY
Kubota B-7800
I've finally put together everything to install the rear remotes on my B-7800. All I need are fittings and hoses.
Now for the questions..
What type fittings are on the Loader valve (LA402)? (JIC??)
What size are they? Everything appears to be plumbed with 3/8 hose...
The fitting at the tank appears to be different from the rest. The return line goes to the side of the tank. I believe that the thread in the tank is a NPT thread?? But, the 90 degree fitting appears larger than that on the loader valve and the hydraulic block.
Also need a fitting to Tee in my second return to tank line.
Finally, what size Snap-Tite QD fittings are on the loader valve??
Does anyone have a list of fittings for doing this job??
/ B-7800 hydraulics #2
The Husco valve on my LA 853 loader has -8 O-ring boss outlets and inlets. The pump, tank, and power beyond are fitted with adapters to -8 JIC male flare. The 3/8 hoses then have adapters: -8 JIC female swivel for the loader valve and -6 for the 3/8 hose.
The work ports have adapters for -8 O-ring boss to 3/8 NPT (male). The 3/8 quick disconnects are 3/8 NPT (female) and are screwed to the 3/8 NPT male on the valve. The hoses to the loader cylinders have 3/8 NPT (male) ends to attach to the other ends of the quick disconnects.
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
Unverferth 330 (A64126)
Unverferth 330...
