B-7500 Won't crank. HELP
   / B-7500 Won't crank. HELP #1
crown
Platinum Member
Winchester, VA
Kubota B-7500
B-7500 Won\'t crank. HELP
I used the tractor on Tuesday to clean up from a small snow everything worked fine I pulled it into the garage and shut it down, when I came home tonight I decided I would move it back to the shed, it will not crank the battery is good lights work everything is in neutral ie PTO is not engaged I must be missing something stupid. Help Please!!!
   / B-7500 Won't crank. HELP #2
Re: B-7500 Won\'t crank. HELP
Have you activated all the safety cutout switches?
Egon
Explain. I have pushed the shut off buttom in.
Thanks
   / B-7500 Won't crank. HELP #4
Range in neutral?
Yes it is in neutral, it is as if the stop button is not pushed in.
   / B-7500 Won't crank. HELP #6
Make shure all of your safety switches are connected and a wire didnt pop out while plowing. Just a wild guess. JB
   / B-7500 Won't crank. HELP #7
You might also want to check the hardware that holds the safety switches. I had them come loose on my tractor. Both the netural and PTO switches worked themselves loose enough to not fully close the microswitch.
Dave
   / B-7500 Won't crank. HELP #8
So.............does it crank and not fire or does it not crank ????
It will not crank, seems like a saftey switch issue but the PTO and clutch have connection as needed and no apparent wire damage. /forums/images/graemlins/confused.gif
   / B-7500 Won't crank. HELP #10
You may have to systematically check the safety switches with a jumper wire.
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
2014 DRAGON 500 BBL FRAC TANK (A53843)
2014 DRAGON 500...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A53473)
2012 KINZE FLAT...
