B-7500 Won't crank. HELP
   / B-7500 Won't crank. HELP #1
crown
Platinum Member
Winchester, VA
Kubota B-7500
B-7500 Won\'t crank. HELP
I used the tractor on Tuesday to clean up from a small snow everything worked fine I pulled it into the garage and shut it down, when I came home tonight I decided I would move it back to the shed, it will not crank the battery is good lights work everything is in neutral ie PTO is not engaged I must be missing something stupid. Help Please!!!
   / B-7500 Won't crank. HELP #2
Re: B-7500 Won\'t crank. HELP
Have you activated all the safety cutout switches?
Egon
Explain. I have pushed the shut off buttom in.
   / B-7500 Won't crank. HELP #4
Range in neutral?
Yes it is in neutral, it is as if the stop button is not pushed in.
   / B-7500 Won't crank. HELP #6
Make shure all of your safety switches are connected and a wire didnt pop out while plowing. Just a wild guess. JB
   / B-7500 Won't crank. HELP #7
You might also want to check the hardware that holds the safety switches. I had them come loose on my tractor. Both the netural and PTO switches worked themselves loose enough to not fully close the microswitch.
Dave
   / B-7500 Won't crank. HELP #8
So.............does it crank and not fire or does it not crank ????
It will not crank, seems like a saftey switch issue but the PTO and clutch have connection as needed and no apparent wire damage. /forums/images/graemlins/confused.gif
   / B-7500 Won't crank. HELP #10
You may have to systematically check the safety switches with a jumper wire.
2019 JOHN DEERE 325G SKID STEER (A52706)
2019 JOHN DEERE...
2008 Komatsu WB146-5 (A47477)
2008 Komatsu...
Unused 2025 LandHonor LDH-KN16 Mini Excavator (A52377)
Unused 2025...
2017 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2017 DRAGON...
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
