B 7500 MMM or RFM
   / B 7500 MMM or RFM #1
ejs461
Thanks to all that helped me to decide on the B7500HST. It arrives on Tuesday. My new dilema is deciding between a MMM or a RFM. I have to mow approx 4 acres of open meadow with relatively few trees in the way. I am leaning towards a Woods rear discharge 60" RFM. Any thoughts? And again thanks to all- my first tractor, I can't wait.
EJS
   / B 7500 MMM or RFM #2
Click here for one of many prior discussions on this topic.
   / B 7500 MMM or RFM #3
Using a mmm on my 7500 to cut 3 acres takes just over an hour. Never tried the rear mower. The only trouble I have is attaching and removing it. The rear is probably easier.
   / B 7500 MMM or RFM #4
For that much land I would go with the RFM. The MMM is just going to be a pain in the **** to take off and put back on. It is also more expensive. You will be happier with the RFM.
Thanks,
Knowles
   / B 7500 MMM or RFM #5
welcome to the forum! get the RFM u are not cutting lawn , u are cutting grass, the rfm is much easier to remove and install. if u decide to go RFM get the rear discharge with chain guard.
   / B 7500 MMM or RFM #6
I was talking mowers with a friend of mine the other week. I was using a SD the dealer lent me until my RD RFM came in and said to my buddy that the only thing I didn't like about it was that it seems to leave the grass in clumps. He used to own a landscaping business and now owns a campground (lots of acreage to mow) and said you won't see any landscapers using a RD because the SDs cut the grass finer because of the mower deck design and the blades throwing the grass towards the chute. I think my tractor tends to lug down more with the RD, too. There's lots of pros and cons for both. There was lots I didn't like about the SD while I was using one.
As far as mid or rear mount, the only advantage I can see to having a MM is you can attach a roller and roll your grass in the spring while you mow. The RM on the other hand is great for getting under bushes.
Fred
   / B 7500 MMM or RFM #7
Bird has it.
I think the only topic that has had more attention than the MMM vs. RFM debate is how to use a boxblade (excluding that Chalkey thread). Do an "all word" search on "rfm mmm" and if you don't find the information you're looking for, I'll be a monkey's uncle.
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
Service Truck Hydraulic Rear Liftgate (A55787)
Service Truck...
2014 Freightliner M2 106 5.1Yds Asphalt Pot Hole Patcher Truck (A56858)
2014 Freightliner...
Meyer 10' Snow Plow w/Bracket (A55272)
Meyer 10' Snow...
