B-3030 lift arms
   / B-3030 lift arms #1
BlacknTan
Platinum Member
Adirondacks of NY
Kubota B-7800
Has anyone ever investigated the cost of swapping the extendable lift arms from a B-3030 to a B-7800 for the 3PH?
It must becheaper than a Quick-Hitch setup?
   / B-3030 lift arms #2
Sit down and hold on tight when you price these things!:eek:
I did look into doing this kind of swap, wanting to use the B2910 extendable lower arms and to adapt them to my BX...
Would have cost over $400 for parts alone...or was the $500 :confused:.
Crazy expensive... There have been past threads on this subject. You might find them with a search...
(edit: somehow this got posted while I was typing...
   / B-3030 lift arms #5
It ain't, nor is it as good as a QuickHitch (which $200 at your local TSC will get you)
B2910 (with extendable lower links), Speeco Cat1 QuickHitch
   / B-3030 lift arms #6
I think I'm going with Pats QH set up my self. My ballast drum is on and off my tractor a lot. It weighs over 800 pounds and if I don't back to it perfect and thread the needle just right it can try your patients. Its fine in the shop on a pallet jack but out on the ground its a pain
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
