B 2910 Hydro oil level
/ B 2910 Hydro oil level #1
dlabrie
Campton, NH
Kubota B2910
Hi, I just finished the 6th or 7th 300 hour service on my 2001 b2910.
The manual specifies 3.83 gallons of hydro oil after a filter and hydro oil change. The last time I did the 300 hour maintenance, I made a note that the dip stick registered over filling. So, this time I only put in 3 gallons and it still reads just above the fill line.
I drained the oil from the plugs at the bottom of the front and rear transmission case. I replaced both hydro filters and cleaned the transmission strainer.
Should I be worried that I put almost a gallon less oil in?
Also, how does anyone see the oil level on that yellow dipstick! I have to lay it on a paper towel to see where the oil is.
/ B 2910 Hydro oil level #2
Burn it a little
/ B 2910 Hydro oil level #3
Very likely when you drain it there is quite a bit left in that you cannot drain out. A little overfill is not going to hurt anything either. Also, you should run it around a little and get things fully operational after the fill and then top it off. There may be some difference after running it.
2022 Ram ProMaster 2500 Cargo Van (A64556)
2022 Ram ProMaster...
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2023 ASV RT-25...
2020 BROWN AND HUBERT 10' SPOOL TRAILER (A63276)
2020 BROWN AND...
HARDEE 300 GALLON SPRAYER (A64278)
HARDEE 300 GALLON...
