B-26 Hydraulic Pump Noise?
   / B-26 Hydraulic Pump Noise? #1
CurtisC
Elk Park NC
Kubota B26TLB
I recently performed 400 hr. service on my 2009 B-26TLB. While there's not a lot of hrs. on it, this machine has had a moderately tough life pulling trees/ stumps and working in rocky hillsides cutting in roads and has always performed well. I started noticing a new whining/rattling noise (I assume from the hydraulic pump) after the engine had a couple of minutes warm up time and with no demand placed on the hydraulic system. Raise the bucket or otherwise load the system and it quiets down - it also quiets down after its been working a while. Some other background data: 1. Air temps at start up were cool but not cold mid 40's - 50's. 2. The hydraulic system had seen some standard hyd. oil for a brief period in it's early life (around 50 hrs.) but the system was flushed and refilled with Super UDT and just received a new load of same along with filters at 400 hr service. 3. The noise is a similar to the "whine" heard when wrong oil was used or when tractor is first started in very cold weather mixed with a bit of "rattle" - its almost as though something's loose and rattling to engine vibration. I've poked around and looked for a loose anything with no luck. 4. Hydraulic performance (transmission, B/H, loader, & Pwr steering) continues to be good but I did notice some momentary hesitation the other day in the power steering after warm up while driving uphill in a tight spot. 5. The B/H does come off and on a fair amount but I can't remember if noise showed up immediately after a reinstall or not.
I'm somewhat sensitive to the sound of running machinery and always suspicious of change. For those of you familiar with Kubota hydraulics - thoughts?
   / B-26 Hydraulic Pump Noise? #2
All I can tell you is that my B21 has always had a whine like you describe. After it runs for twenty minutes or so it goes away. I used to wonder about it but after years of hard work, it is no longer a concern.
Thanks troutsqueezer, interesting that you were the only reply. "Noises" are pretty tough to figure especially if all you've got is someone's description to go on - however it was the change that got my attention. Not much to do but press on as you did and monitor hydraulics performance.
   / B-26 Hydraulic Pump Noise? #4
My understanding is that generally a whine in the hydraulic system is air in the lines... If it goes away after some running time it may be self purging. I recently changed all my hydraulic fluid and had a whine... I ran all the PTOs and raised and lowered the 3pt and loader and finally it went away....
Regards,
Chris
   / B-26 Hydraulic Pump Noise? #5
I put 1200 hours on a B3200 purchased in 2012. It whined the day I bought it and the day I traded it. Did all the maintenance at the scheduled hours. I located an L3901 at a dealer that seemed not to whine as much. It was gone when I went back to purchase it. The L3901 I did get whines and I have resigned myself to the fact that it does. I run it with ear muffs that have a radio. Just tune the radio to my favorite station and play in the dirt.
Chris,
Makes sense, I have yet to run the 3PH full stroke and the PTO. I'll give that a try.
Thanks,
Greg
Deere 331G (A50123)
Deere 331G (A50123)
2025 K4525 UNUSED Double Garage Steel Barn (A53117)
2025 K4525 UNUSED...
FAKE (A52472)
FAKE (A52472)
2019 Autocar Xspotter Truck (A52384)
2019 Autocar...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
