AZUNO lock-on grase fitting coupler?
   / AZUNO lock-on grase fitting coupler? #2
I don't have that particular brand, but it appears well made in the picture (for whatever that's worth!)
I do like the concept, and have been using the LockNLube brand for the past year. Coupled with a DeWalt electric grease gun, I almost enjoy greasing! My Kubota ZD mowers have like 15 grease fittings, so anything that makes the job easier is a big plus.
Thank you
   / AZUNO lock-on grase fitting coupler? #4
Looks well made but reviews are mixed on it.
I also have a LockNLube on a Dewalt gun. I have mixed results with it but I'm too lazy to change it. Sometimes I have trouble getting it to lock on. Some fittings I have to use a short extension with the standard coupler on because the LockNLube won't get to it. One of these days I'm going to just stick the regular coupler back on the gun.
   / AZUNO lock-on grase fitting coupler? #5
I have a Lock-N-Lube unit. I've quit using it with my DeWalt electric grease gun. The outside diameter of the L-N-L unit would not fit into some of my recessed grease zerk locations. This unit might be better. It just might be a tad smaller in diameter. At least, enough to fit into my recessed locations.
   / AZUNO lock-on grase fitting coupler? #6
I have the "Lock & Lube" unit and it will not fit in any of the recessed fittings on my 3054 Kioti
   / AZUNO lock-on grase fitting coupler? #7
Never seen the need for a 'lock on coupler'. Ordinary grease couplers (at least most of them) are 2 piece. The nose and the body are seperate and the nose applies pressure on the collet assembly that grips the end of the Alemite fitting so, if you want a firmer grip, just tighten the nose, looser grip, loosen it.
In my view, the lock on couplers are a solution looking for a non existent problem.
   / AZUNO lock-on grase fitting coupler? #8
These lock on couplers seemed to be the talk of web a while ago.???
   / AZUNO lock-on grase fitting coupler? #9
Clearly the LockNlube style is not for everyone. It fits in the recessed zircs on my L4060 FEL, and makes my greasing routine easier, and faster.
   / AZUNO lock-on grase fitting coupler? #10
I have one of each. A Lock n'Lube and a Azuno. The Azuno is MUCH larger that the LnL. There's no getting into tight spaces with the Azuno.
DEWFPO
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
2024 VOLVO VNL760 SLEEPER TRUCK (A54607)
2024 VOLVO VNL760...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2011 Liebherr L586 Wheel Loader (A55218)
2011 Liebherr L586...
2006 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A54607)
2006 FREIGHTLINER...
