Aztec, small front-end loader machine...
/ Aztec, small front-end loader machine... #1
MichaelO
Hello Folks,
I have an input gear problem in the gear drive to the differentials in a little Aztec loader that was made by Azmuth Engineering of Chicago in the 70's, I believe. I haven't been able to find out any info so I'm looking for any help... it's like a small bobcat but it articulates in the middle instead of being a skid-steer. I would like to get ahold of the input shaft from the hydraulic drive motor to the gear that drives the diffs, half the shaft with the small toothed gear is inside the gear case. It's a 3/4" shaft with a keyway for the coupler from the hydraulic motor and a pressed on(?) gear about 1 1/2" long toward the end that mates up with the large gear inside the drive case, total length of the shaft is about 5" long. It's quite worn so I'd like to replace it with a new or used one, rather than have a machine shop make it for me. Thanks for your help... the snow is coming!! -Michael
/ Aztec, small front-end loader machine... #2
Can you post a picture of the loader and the driver train part your missing, I think there may be one in the junkyard near where I work. It might also be a common part between 2 gear sets to.
Thanks for your reply, I'll take a couple of pics and post them or I can e-mail them to you... I really appreciate the help! -Michael mor@fireman.net
set of 4 tractor trailer tires Roadforce (A63118)
set of 4 tractor...
New/Unused Landhonor Quick Attach Power Rake (A61166)
New/Unused...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
2018 TAKEUCHI TB260 EXCAVATOR (A62129)
2018 TAKEUCHI...
2014 Chevrolet Caprice Sedan (A61569)
2014 Chevrolet...
2017 BX2680 Sub Compact Utility Tractor (A63118)
2017 BX2680 Sub...
