Axle Seal
   / Axle Seal #1
DrRon
Jones, OK
JD 3020, JD 830, JD - A
My John Deere Model A has a leaking left axle seal. Any idea the cost for repari? Any idea where I can get a replacement?
   / Axle Seal #2
What model year..?? I'd have to guess there are different seal for the un-styled/styled models. Cost would depends on who does the work. You, local mechanic, or dealer. Seal is probably still available through John Deere, but looking up the part number on their site, then crossing the number may be less expensive for the same brand seal.
   / Axle Seal #3
In order to R&R seal which is part # AA510R/gasket A412R one needs to remove rockshaft housing then remove bull gear. The part #s are for A with serial # 477,000 up
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A59231)
2009 Skeeter SL190...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
Towable Centrifugal Water Pump (A59228)
Towable...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2019 Ford F-350 (A55973)
2019 Ford F-350...
