Axle play On ym155d
   / Axle play On ym155d #1
tractordriver
mahindra 3525
I have A ym155d That the rear axle seal is leaking. Before i just replace the seal i want to make sure the bearings are good. There is a very slight amount of play.
Is this normal or should there be zero play. I would like to here from someone with experience with this tractor model or ym1100, ym1300, ym135 And (d) as the axle is different than larger tractors. I also have a ym2000 That the seals both leak any advice. I have seals for both already thanks hoye. Also ym1300 parts tractor Thank you.
   / Axle play On ym155d #2
I don't have any hands on experience with the YM155D, but here are a couple of scans from the service manual. It looks to me, in (4) under the Rear Axle Shaft Assembly, that there should be no play between the rear axle housing and the bearing. Hope this helps.
The scans don't look so good when you click the link but they are legible if you enlarge them.
Bruce
2017 Kubota M5-111D Tractor (A52377)
2017 Kubota...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
1999 Honda VT1100C Motorcycle (A51694)
1999 Honda VT1100C...
2016 Dodge Journey SUV (A53424)
2016 Dodge Journey...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
