B2400
Platinum Member
- Joined
- Jun 13, 2003
- Messages
- 586
- Location
- Western Illinois
- Tractor
- 2016 B2650 ROPS, 1998 B2400 (sold!)
Hello All!
Once again I've encountered a troubling problem and am seeking your infinite wisdom! I've developed an oil leak at the front axle to Bi-speed turn pivot point. I have removed the front trunion carrier and the only seal in it was an O-ring. This one was easy to remove,unfortuneatly not the one leaking. I spoke to a mechanic at the local dealership and I(mis) understood that the entire front axle should pull out from the case to gain access to the rear O-ring(front pinion was to be slip splined to an internal gear on Bi-speed unit). After much carefull pulling,prying and cussing it appears this is not the case. Has anyone had one of these apart that can shine some light on my darkening mood? /forums/images/graemlins/confused.gif
Thanks,
Mike
Thanks,
Mike
