Oil & Fuel Axle fluid
   / Axle fluid #1
pilot-werx
Southern Maine
Stupid question of the day because the dealer is closed and my manual is at the shop.... Does the front axle use the same hy-gard low viscosity fluid as the rest of the tractor?
   / Axle fluid #2
The manual for my JD 790 states to use John Deere GL-5, SAE 80W90 in the MFWD front axle. Don't know if your 4210 would be the same, but I doubt it would use a different type of fluid??? Maybe another can check their manual and say for sure.
   / Axle fluid #4
My 4210 uses Hy-Gard low vis in the front axle - same as the rest of the unit.
   / Axle fluid #6
From manual for your 4210
Add approximately 4.5 L (4.7 qt) of John Deere Low Viscosity HY-GARD (J20D) or HY-GARD (J20C) or equivalent into dipstick filler opening.
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2023 Yamaha YXZ 100R SS (A51573)
2023 Yamaha YXZ...
2014 Peterbilt 384 T/A Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
