axle distance on a trailer?
   / axle distance on a trailer? #1
maplehillfrm
hello all, I think this is in the correct forum, I am currently rebuilding atrailer, it was like 20 feet, I only needed a 12 - 14 foot trailer, it had a bent piece in the front so I cut it out and am now welding the tongue on the rear,, which puts the axle way back from where it is supposed to be, I am never going to put more tan my mower or my rhino on it so tongue weight shouldnt be a problem,,
but what would the correct location be for it in case it is wagging the dog when I test drive it,, the bed is about 14'.. overall is approx 16'.. I may cut it down to 12' bed, but not sure at this time,,figure on it being 16' total, thanks pat
   / axle distance on a trailer? #2
60/40 is a good axle placement
   / axle distance on a trailer? #4
with your axle so far back you won't get any wag, just a really heavy tongue load. Might be fairly inexpensive to get new weld on brackets (spring) and abandon the old ones.
   / axle distance on a trailer? #5
Trust me....if you have to much tongue weight you will get the wag! You should have no more then 10% tongue weight for the total load consisting of trailer and what you are hauling. Basically, if your trailer with a load is 3000 lbs, then you should have about 300# MAX of tongue weight.
Craig
   / axle distance on a trailer? #6
I measured a bunch of "engineered" ones to figure the dimention they were between 50 to 60 % in front of axel (depended on ramps/tail gate and the flat beads were shorter and ramped ones were longer
I built 4 home made ones so far and I used 53% in front of the axe excluding the tung.
tommu
   / axle distance on a trailer? #7
Craig
Craig, of course, it is possible to have too much tongue weight, but 10% should be the minimum rather than the maximum. Ideally, 10% to 15% tongue weight.
here is what I have so far , I welded the tongue on and I measured the axle from the back of the trailer to the center point of the axle it was 3 1/2'
I am thinking approx 5 1/2' to the center point of the axle where I will relocate axle,, the bed is 13 feet,, and the overall lenght tongue to rear is 16'
[sound right??]
I picked up the axle relocating shacles and pins today, but it is raining so maybe tommorow I will do more. thanks pat
   / axle distance on a trailer? #10
maplehillfrm said:
I am thinking approx 5 1/2' to the center point of the axle where I will relocate axle,, the bed is 13 feet,, and the overall lenght tongue to rear is 16' [sound right??]
looks right to me, 5.5' would leave you with about a 1/3-2/3 slpit in the overall length of the trailer, I dont think you want to be any farther forward than that.
Aaron Z
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
Genie GTH-5519 (A50123)
Genie GTH-5519...
Tailgate For Pickup Truck (A53117)
Tailgate For...
PALLET OF SITE FENCE STABILIZERS (A51248)
PALLET OF SITE...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
