</font><font color="blue" class="small">(   The big round thing on the end sounds like a slip clutch and it does go on the mower end ... (This is very important) ... which must be adjusted ... You will need to accomplish at least two major things before you go and start cutting ... make sure the shaft is the right lenght and if it isn't you will more than likely have to cut both shafts to get it the right lenght. And number two you need to adjust the slip clutch ... read your manual with your cutter for the mfr's reccomendated methods for both setups.)</font>
Noooooo.  OK, I didn't mow last night.  I have to go research and find threads to print out to do adjustments now?!
I have a built in cat to deal with.  Yes, building a farm and moving in before it is done has some risks.  The cat found a hole from the unfinished stairs...into the space between the 1st and second floor.  Stair guy came, installed last stairs, railing and left.  A few hours later my stairs started meowing.
Why me?  Why can't that blasted thing just be plug-n-play?  Oh well, Off to research...but I'd happily accept links to existing threads  /forums/images/graemlins/wink.gif.
Mel
