Avoid Cumming GA Dealership - At all costs
   / Avoid Cumming GA Dealership - At all costs
Ford 850 and mred2
ok guys - maybe your comments are possible to explain injector pump #1, please explain how that could cause injector pump #2's failure?
I mean - clean tanks, clean pipes, new injector pump, and fuel from the dealership - so not from my station.
If the Branson's are so impacted by water in the fuel - then we would be seeing a huge amount of similar stories. And we are not...
We have an old Massy 230 down at the deer lease with a metal tank, it sits for months at a time without being started, yet the old girl fires up and runs like a top, no attention is taken to keep the fuel tank full, the fuel filter on it is nothing special.
By both of your posts that tractor should never run, the fuel containers for the Massy are plastic, they sit outside for months at a time as well... fresh fuel is taken only during food plot planting, otherwise it is old fuel.... why does that not cause the Massy to fail...
Yes my Ram has a FASS on it with a water separator, but it has not required being emptied, running the same fuel as the tractor.
Ford850 - yes I bought my first Mr. Funnel in 2013, after a fuel incident with a generator.
mred2 - "May not get hot enough to burn off water." What do you mean - how hot an engine on a tractor gets has no impact on water absorbed into the fuel in the tank
- I am not following you on this...
The heat of the engine has an impact on the DPF cycles - but not the fuel in the tank.
   / Avoid Cumming GA Dealership - At all costs #72
Was injector pump 2 a rebuilt one or factory new?
   / Avoid Cumming GA Dealership - At all costs #73
I was gonna say you would see water in the separator on you're truck if the fuel you are buying had water in it.. It's a mystery.. I think we are missing information from the people in the fixing process, we will never know..
Atsah - I agree, and with that.... I am going to drop from this thread, as I have a new 2019 3520R with all of 6 hours on it.... Time to get off the forum and get on the tractor. I thank everyone for their insight and comments. There are some interesting items in the new manual I will share in a new thread - like every 2 years - Replace your Electric cables...
Thanks all
   / Avoid Cumming GA Dealership - At all costs #75
Thanks all
Good luck with you're new one, purchasing another Branson after all this says a lot about the brand and tells me you are a pretty patient guy..
   / Avoid Cumming GA Dealership - At all costs #76
I was shown my old fuel sending unit that they removed/replaced - it was corroded to heck and back again...
I am still not understanding how corrosion can occur in a tank of diesel - I normally try to keep the tanks as full as possible.
I'm just spit ballin' here. Fuel stored outside in 5 gallon cans (plastic containers), and a sending unit severely corroded. Very possible the fuel had moisture accumulated which corroded the sending unit, and contaminated the rest of the fuel system. I know you said you used Mr Funnel, but did you do that from day one? Maybe it only removes separated water, and not water absorbed into the newer diesel.
Ford 850 and mred2
Piecing it together from the OP, mechanic, and dealer replies I think it can make some sense. Water in fuel from years ago could have deteriorated the sending unit/lift pump. That caused the first injector pump to fail. The dealer tested the lift pump and it tested fine, so they replaced the injector pump and fuel filter. Tractor runs fine for a few hours then second injector pump fails. Dealer then checks fuel system more thoroughly and finds rust in tank and corroded lift pump. That's when they replaced the lift pump, cleaned everything, and replaced the injector pump again.
Who knows where the water came from. Gafn, you mentioned having a previous fuel incident with a generator, and that you hoped the funnel would remove algae from fuel. Algae is caused by water in fuel, so that goes back to a cause for corrosion. Or maybe water was in the tank when you first bought the tractor. Either way that sending unit which was corroded to heck and back again, is the smoking gun in my mind.
I'm glad you got a new tractor, and by reading your other posts it sounds like that's a better model for you too. :thumbsup:
That generator fuel incident was back in 2013 - that old tractor was a 2015... so not related...
Yes I am loving the "R" model more and more... picked up a Grapple with the new tractor and freaking love that thing.... I can clear brush in the summer without fear of snakes... hate the dang copperheads, would much rather be on the tractor than on the ground.
   / Avoid Cumming GA Dealership - At all costs #78
I've never tried to do this, is it possible for an OP to change a thread title?
   / Avoid Cumming GA Dealership - At all costs #79
It's annoying when you discover a typo. I always wondered why it was set up that way. Probably the way the database has to set up.
Yea - one thing I hope this thread shows is that I was always happy with my 3520H.. prior to the visit to the dealership - it was really reliable...
recap of my issues:
with less than 50 hours the hydro hose from pump to pedal housing blew - I figure a bad hose... crap happens - no big deal replaced and good to go
with 180 hours on it the fuel gauge stopped working
Around the same time the dashboard/Hour meter began resetting itself to zero hours
Other than those issues - I put 246 hours on the tractor in 4 years and never had another issue - so I am VERY HAPPY with Branson.
That is why I bought another one, and I fully expect this one to be passed onto my boy when I can no longer climb up onto it.
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52128)
2017 Ram 5500...
Quick Attach Accumulator Grapple (A50514)
Quick Attach...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2012 International Day Cab Truck Tractor (A50323)
2012 International...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
