auxillary ports on a 1070
   / auxillary ports on a 1070 #1
mikehaugen
Elite Member
Lee, IL
John Deere 1070
I own a j.d. 1070 with the joystick and front loader ports and would like to add another valve for rear aux. hydraulics. Is there another port somewhere that I could tap into to do this. There are 2 couplers on the back above the top link with a hose connecting them. I could maybe use that but I am not sure if it needs to have constant flow there. I don't want to cause pump damage by blocking that flow. Why else would there be a hose connecting them to each other? If someone has a 1070 or knows them well maybe you could help me out.
   / auxillary ports on a 1070 #2
The hose at the back sounds like a power beyond line-did/does this machine have a backhoe?
If it is indeed a PB line, the it has full pump flow whenever the tractor is running, so you can add a new open center valve into that loop.
Got a picture?
2018 Ford F-150 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
HUTCH TANDEM AXLE (A51247)
HUTCH TANDEM AXLE...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
