Auxiliary service port on a 1910
   / Auxiliary service port on a 1910 #1
jezorek
NJ
Ford 1910 w/1710 FEL
Attached is a photo from my 1910 manual showing the location of the auxiliary service port. The instructions say that this can be used to supply oil to an aux cylinder when the lift control lever is placed in the notch in the upper part of the quadrant.
This description is pretty vague. Can this port be piped to a control valve or to an attachment? Where is the return?
   / Auxiliary service port on a 1910 #2
I don't have that model.. but am thinking it is for a SA type application.. originally.. like a lift axle on a disc or mower.. etc.
I guess you could plumb in an OC type valve.. with 1 or 2 SA or DA ports on them.. then plumb a return line back to the sump.. ( many people take the cap off.. and drill and tap it for a hose barb fitting and then run the low pressure return to sump line to that.)
Soundguy
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
JLG 1255 Telehandler (A53472)
JLG 1255...
2013 Husqvarna YTH18542 42in Riding Mower (A51694)
2013 Husqvarna...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
