Auxiliary service port on a 1910
   / Auxiliary service port on a 1910 #1
jezorek
Bronze Member
NJ
Ford 1910 w/1710 FEL
Attached is a photo from my 1910 manual showing the location of the auxiliary service port. The instructions say that this can be used to supply oil to an aux cylinder when the lift control lever is placed in the notch in the upper part of the quadrant.
This description is pretty vague. Can this port be piped to a control valve or to an attachment? Where is the return?
   / Auxiliary service port on a 1910 #2
I don't have that model.. but am thinking it is for a SA type application.. originally.. like a lift axle on a disc or mower.. etc.
I guess you could plumb in an OC type valve.. with 1 or 2 SA or DA ports on them.. then plumb a return line back to the sump.. ( many people take the cap off.. and drill and tap it for a hose barb fitting and then run the low pressure return to sump line to that.)
Soundguy
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A51572)
2006 Volvo VNM...
New/Unused Agrotk Horizontal Band Sawmill (A51573)
New/Unused Agrotk...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A51572)
2014 Ford F-150...
