Auxiliary fel post driver
/ Auxiliary fel post driver #1
FF110
North Carolina
John Deere 110 TLB, John Deere 4230, Satoh 650G
I have a shave hd8 post driver that I want to convert from a 3pt hitch to a quick attach style mount. My question is about the hydraulics. I planning on using it on a jd 110 tlb with the flat face aux hook ups on the fel. Is it possible to operated the post driver off these hydraulics and if so how do I hook it up. My post driver valve has 1 inlet hose and a return hose that goes straight back in the hyd tank. I will run the return hose back to the tank but do I need to add a power beyond plug to the post driver valve and have 2 lines running to the aux hookups on the fel or will the 1 be ok. I'm not sure if it needs both lines to make a complete circuit. Also as you can probably gather I have a lot to learn about hydraulics so any I'm put is appreciated. And I'm pretty sure that my post driver has a prince valve on it. Thanks.
Colombo CTA 6500 (A64119)
Colombo CTA 6500...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
ROADTEC RX700 MILLING MACHINE (A64279)
ROADTEC RX700...
2017 International HX620 Quint Dump (A62613)
2017 International...
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
