Mowing Automatic pto no working
   / Automatic pto no working #1
Rhb798
Clendenin,Wv
Mahindra 3535
I have a Mahindra 3535 with auto and manual pto switch, the pto works in the manual mode but not in the automatic mode, I don't like the auto mode I prefer manual,since the tractor only had 40 hrs when the auto quit working I would just like to get it working, probably never use it,just wondered if anyone else has had this problem.
   / Automatic pto no working #2
It's probably similar to the one on my old 4110. Could be the clutch switch, the seat switch (mine doesn't have one), or the 3 pt hitch all the way up causing it not to come on in the auto mode. I too prefer the manual setting anyway with the on/off switch on my steering column.
Thanks for a quick response, I agree with you about never using it, just like to have all my equipment in perfect working order, guess I'll have to start digging, I know all those switches will be well hiddon, thanks again.
   / Automatic pto no working #4
My 3550 Hydro PTO quit working at all at less than 100 hours. It went back to the dealer and they said it was a bad ground.
   / Automatic pto no working #5
When your engaging it are the 3point levers lower than half way? or raised up?
   / Automatic pto no working #6
if your familiar with the operation of it then its either the fuse, switch or vacuum itself... test light should be able to get you the info you need
Thanks to all for the replies, I have checked all the above listed, except the grounds, I'm sure there are several locations.
   / Automatic pto no working #8
My 4035 did that, it was a bad connection where the switch plugs into the relay.
Where is the relay located
   / Automatic pto no working #10
I just followed the switch wires to the relay
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2019 CATERPILLAR 299D2 XHP SKIDSTEER (A51242)
2019 CATERPILLAR...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
