Automated watering from low pressure tank
   / Automated watering from low pressure tank #1
heitjer
Houston, TX
LS R4041 & LL4100 FEL
Hello All,
I installed a 65 gal water tank at my property to water some shrubs & plants automatically. I purchased a battery operated timer but just found out that this does not work on such low pressure.
I did some research but only found this system in Australia that works on low pressure. I can' t find it or nything similar in the US.
I wonder if you can give me some pointers what battery operated systems you use on your gravity fed watering systems.
Thanks in advance!
heitjer
   / Automated watering from low pressure tank #2
Since I don't know what you have, and do not know what pressure you have--
I'll tell you that I have been using battery operated units for several years.
All of these units just open a valve so what ever pressure is there the water runs.
Some mfgs Melnor Nelson Rainbird.........
Sorry, I could have been more specific:
This is the unit that I purchased at Amazon and it works fine on my house water system where we have decent pressure on the line. But when I use it on the 65 gal water tank (water height 1 to 2 ft = .4 to .8 psi) it will not open. I assume it needs pressure to energise.
Any similar items that I can run remotely?
   / Automated watering from low pressure tank #4
I have a couple gilmour 9400s?
they dont require any water pressure to operate. Theres a battery in it that turns a motor, opening the valve. It will cycle even if the tap is off
   / Automated watering from low pressure tank #5
Once the timer is cycled on and emits water , the next challenge is producing a water flow from the end of the pipe or hose onto the vegetation. You probably won't be able to use the traditional drip orifices rated at 1/2 to 4 GPH unless you have a tremendous tank height above the garden. If dripping is your intent, try using just the spaggetti hose off of the main line. If it works, then adjust the timer for your GPH needs. Keep us informed of your progress!
Thanks all!
I just purchased this timer from DripWorks:
Quote: "This new water timer is the only battery water timer that can run a drip system from a ground level water barrel. It runs a zero pressure and is rain sensor ready."
To Nickel Plate: I am using open ended hoses on my newly planted shrubs and this works just fine in my setting.
   / Automated watering from low pressure tank #7
Yep, you need the kind with a motor operated valve vs. the kind that has a plunger/pilot hole that uses (high) water pressure to operate main part of valve ala lawn sprinkler valve. Looks like you have found one. I have used Gilmour, but last time I needed one and went shopping, they had changed the design away from motor-operated!
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A54607)
2020 KENWORTH T680...
2010 International Prostar (A47477)
2010 International...
CUSHMAN HAULER PRO GAS GOLF CART (A54756)
CUSHMAN HAULER PRO...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
