Auto style cruise for 3520
   / Auto style cruise for 3520 #1
jmt1271
Platinum Member
MO
Kubota L2501
I have the standard cruise on my 3520. Never thought Id need the auto style. But while mowing and tilling I find it would be nice to just bump up the speed with a switch as opposed to shutting down the cruise, setting the new speed and resetting the cruise. What is involved with upgrading to auto style cruise? What parts are needed and what is involved with the install? Prices?
Also, can I order directly off JDs website? Do you all order from JD or is there a cheaper alternative?
Thanks, Jeff.
   / Auto style cruise for 3520 #2
Jeff, the auto style cruise is really simple to install.Part # LVB25548. Cost $86.00. Remove the console cover and plug in to the same plug as the standard cruise switch. The only problem I ran into was programing it, but I resolved that by disconecting the battery.
   / Auto style cruise for 3520 #3
Definately worth the $86. Buy then and install them when adding your light switches.
   / Auto style cruise for 3520 #4
The auto cruise works great for what you just stated, bumping it up and down to control the rpms within the operating range.
You can order parts on the site. They will go to whatever dealer you choose. They are the same cost on the site as thru the dealer.
DW, what was involved with programming it?
   / Auto style cruise for 3520 #6
Jeff, complete instructions are provided with the new switch.Its just a matter of following the instructions to install and program the new switch. You use the mode switch to scroll thru to the numbers they require and the turn signal switch to change the numbers. You have to do it in the required sequence. My problem was that as I went thru the instructions at about halfway thru I could not get the proper sequence to come up.So the following day I disconected and reconected the battery and was able to get the required number sequence. It really quite simple. And as Bloomington Mike said well worth the money.
Caterpillar 315C L Hydraulic Excavator (A53421)
Caterpillar 315C L...
2014 COMPTANK ACID TRANSPORT TRAILER (A55745)
2014 COMPTANK ACID...
2012 MACK CXU613 DAYCAB (A55745)
2012 MACK CXU613...
2014 CAT CT6 (A55745)
2011 COMPTANK ACID TRANSPORT TRAILER (A55745)
2011 COMPTANK ACID...
1999 GMC C7500 Mason Dump Truck (A55852)
1999 GMC C7500...
