Auto Engine RPM
   / Auto Engine RPM #1
chesternator
RK37 HC Hydrostatic Cab
On the dash is shows a min RPM and a picture of the auto function. Is this to mean you should operate at that min before engaging auto function?
   / Auto Engine RPM #2
Where are you seeing the minimum rpm? There's nothing in the manual linking rpm's with auto throttle that I can find. I pretty well use the auto throttle all the time except when using an attachment using the PTO function. The only thing I can see dealing with rpm min/max is the PTO rpm range on the tachometer.
   / Auto Engine RPM
It should be no surprise that its not in the manual.
Dead center on my tach (rk37) it says min with a picture which is the same picture that is on the auto throttle button.
I assume this either means operate at this min if using auto throttle or auto throttle will advance to this rpm as a minimum
   / Auto Engine RPM #4
If it's the same thing as the center of the tach on the RK55 (says n/min under an engine symbol) I think it's just a label for the gauge. Don't think it has anything to do with the auto throttle.
1263 (A50490)
1263 (A50490)
197637 (A50459)
197637 (A50459)
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2015 BMW X1 sDrive28i SUV (A48082)
2015 BMW X1...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
Scrap Metal Pipe (A50860)
Scrap Metal Pipe...
