Auto-Darkening Welding Helmet
   / Auto-Darkening Welding Helmet #1
picker77
Central Oklahoma
JD 3032E, dual remotes, TnT, tooth bar, grapple
After all these years, I'm finally going high-tech, have just ordered a new Hornell auto-darkening helmet, and can't wait to try it out! Are there any special tidbits I need to know about using one of these things? I ordered Hornell, but noticed Hobart/Miller sells a similar rig. Hope I did the right thing by buying the Hornell. I do only simple AC/DC stick welding.
   / Auto-Darkening Welding Helmet #2
Well I hope not to spoil you but I've had a Harbor Freight one for about 2 years or so. $49. Came with some extra plexi and lens.
Best thing since pre-cooked bacon.
   / Auto-Darkening Welding Helmet #3
Picker, Do a search for this thread. I don't think anyone has a problem with these helmets. They are too useful. I also have the cheapy HF helmet. Has worked better than expected so far.
   / Auto-Darkening Welding Helmet #4
I'm probably too late since you said you ordered your helmet. I also bought a HF $49. autodarkening helmet and have used it for over a year now without any problem.
George
   / Auto-Darkening Welding Helmet #5
The only issue I have had with some of the less expensive ones is the turn on time can be a little long. This results in a little flash to the eyes before the shade fully darkens. I am in the habit with mine to close my eyes untill the arc is established. Also some of the less expensive helmets are self powered from a solar cell on the front below the lens. You need to keep this clean. Also sometimes when working down inside a tight space, you might strike an arc and not get enough light to the cell to power the darkening feature due to the structure being welded casting a shadow... Other than that, very nice to have both hands free to hold work and welder and not have to flip down a lens or hood.
   / Auto-Darkening Welding Helmet #6
picker77: "You're gonna like the way you look....I guarantee it." /forums/images/graemlins/wink.gif
   / Auto-Darkening Welding Helmet #7
I have the speedglass insert in my regular helmet. It made me a better welder right off the bat. I am going to get a miller soon though, cause I get "flashed" sometimes when I tig. Doesn't happen with mig though so I can still use it. The better auto darks have multiple sensors to help eliminate flashing or interuption of protection while welding. I do like the variable shade adjustment option too. Right now I have a fixed shade 10 which is not dark enough sometimes. You will like the auto dark!
   / Auto-Darkening Welding Helmet #8
They are fantastic. I have had a $49 HF one for a cuple of years and love it.
Ben
   / Auto-Darkening Welding Helmet #9
One thing I learned with my cheapy auto-dark helmet (can't remember the brand) is that if you use it outside in cold weather, the LCD response can get slower such that you get a lot more of the flash and then it stays dark a bit after the weld as well.
The other thing that can happen outside with mine is that sometimes a bright reflection of the sun off something shiny (like clean aluminum ready to be welded) will trigger the thing to go dark when you least expect it.
- Rick
   / Auto-Darkening Welding Helmet #10
I love my $49 HF helmit!!
I went from...."Gee...it'd be nice if that weld was a half inch to the left...where the joint is." to "Well,I'll be danged...nothing broke!!!"
I do get a few false darkenings from the lights or shiny stuff,but it sure beats welding my vise grips down.... /forums/images/graemlins/grin.gif
2001 Chevrolet Suburban (A51694)
2001 Chevrolet...
Pallet Fees (A50775)
2023 Zimmerman 4000 XL (A53472)
2023 Zimmerman...
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
2017 Rogator RG1300B Dry Fertilizer Applicator (A53472)
2017 Rogator...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
