Austin Western for farm use
   / Austin Western for farm use #1
Mac in PA
Somewhere North of the Mason Dixon Line
Kubota L 3800, Austin Western Pacer 100
I recently aquired a 1963 Austin Western Pacer 100 with a 3-71 Detroit. It came with the eleven scarifier shanks and an extra tire and wheel but no V-plow, which I had no use for anyway.
I made a set of ripper shanks for deep till and tried them out on the lower 5 acres. Everything seamed to work really well, even after getting a ripper shank caught on a rock that refused to move. That brought things to a screeching halt in a hurry. I simply raised the rippers, pulled forward and set them back down in the ground (no bent shanks). :thumbsup:
The max working depth is 24" but in this hard compacted soil I've been running them at about 16".
Mac
   / Austin Western for farm use #2
Nice machine! Doesn't look 50 years old.
I recall that the feed mill on the farm in the late 1960's had a 4-71 and it made quite a sound when you loaded it up with corn.
I am curious about the design of the rippers; the shanks seem to be narrower than the lower parts. Was that to make them fit the existing holder? Seems like the narrower shanks would establish the amount of force they will withstand.
   / Austin Western for farm use #3
Down below the Mason Dixon, we call that monster a "Road Patrol!!"
:thumbsup: :cool2:
I wasn't sure how much stress the scarifier frame work would endure so this had a big influence on the ripper design.
I chose the parabolic shape because it supposedly requires less horsepower. It's hard to tell from the pictures but the width at the wings is 8". The shanks are 1" by 6" and 26" long, spaced 22" apart. They create about 4" of lift, which seems to fracture the soil very well. There is 6" of additional support on the rear and sides of the shanks and 1" on the front. The shanks slide up into this channel and the two 5/8" bolts basically keep them from dropping out the the bottom.
My original thought and design was to keep them narrow for less drag and to keep a weak link in the system to protect the scarifier frame work. The original design I tested did not have the front, rear and side support. It relied on the two bolts to keep everything together. The bolts acted as sheer bolts and would break when I hit a rock. This became very time consuming putting the shanks back on and 5/8" grade 5 bolts aren't cheap.
Since the scarifier frame work seems to be stronger than I expected I don't believe I need a weak link to protect it.
At this point I am considering adding additional support to the sides of the shanks to prevent any possibility of them bending. Looking back a better choice would have been to use 1 1/2" or 2" thick shanks.
Mac
   / Austin Western for farm use #7
I think that is the first machine of that size that I have seen with a single rear axle, most have twin live axles on the rear for extra traction. Those rippers look like they will handle a good sized rock without bending. Using those on you pasture will certainly loosen up the soil and allow all those rocks to come to the top so be prepared to do some rock picking later.
Very nice machine, bet it will clear some snow of a road too not to mention the road bed maintenance function of it. As long as you operate it efficiently/expertly it will keep those dirt/gravel roads in shape too.
   / Austin Western for farm use #8
Nice machine!
   / Austin Western for farm use #9
When I was growing up the local highway maintenance depot always had two of those Austin-Western graders. The later ones looked exactly like yours, the older ones had a slightly different cab. They graded dirt roads in the summer and in the winter they mounted a big V-plow and wing for snow removal. They were unbeatable (if slow) punching through big snowdrifts. You could hear that screaming GM diesel coming for at least a mile away. Yours looks to be in "like new" condition. They are great machines, with 4 wheel drive and steering. Nice setup.
   / Austin Western for farm use #10
That is a really nice road grader...
I don't ever remember any of those types down here in NC, only Gallon's...
I guess that with minimal snow down here the 4WD was not needed...
May I ask where you were able to get a machine like that?
Kubota RTVX1140 (A50121)
Kubota RTVX1140...
2013 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2013 Chevrolet...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2015 Ford F-150 4x4 Pickup Truck (A50323)
2015 Ford F-150...
