auger damaged when shear pin sheared on front mounted blower for Cub Cadet 3235
   / auger damaged when shear pin sheared on front mounted blower for Cub Cadet 3235 #1
gmelectrician
I could use some advice about my Cub Cadet front mounted snow blower (353 45" Snow Thrower, 190-353-100) on my Cub Cadet 3235 tractor.
A shear pin on the left auger (looking from front) broke yesterday while I was doing several drives. I drove back to the barn to change the shear bolt. I have only sheared 1 other bolt and that was last year. I bought it as almost new 2 years ago. The guy I got it from said he never used it and the dealer he got it from only used it a couple of times as a floor model. It shows very little use. I got the auger freed up and rotated it so I could put the new bolt in. I could see the bolt was still in the shaft, so I got my punches out. However, the shear pin must not have broken the way it should. On one side, the pin is actually bent over the shaft about 1/16" and a little less on the other side. The holes on the auger for the shear bolt are now both damaged. It looks like the bolt made both holes a bit oval...one is worse than the other.
I know I can get the broken bolt out, but I am wondering if I should just drill a new hole for the shear bolt. I was using the shear bolt that came from my local cub dealer.. part # is 710-0891 (5/16-18 x 1.75). I put 2 new shear bolts in when I got the blower just to make sure the right ones are installed. So now I would like some advice. Should I get the old bolt out and clean up the holes on the auger with a round file? Or should I make new holes on the auger (90 degrees from the original holes) and use the same hole in the shaft? Or should I make new holes on auger and shaft? I am leaning towards removing the broken bolt and cleaning up the holes, but I don't want to be shearing bolts all the time due to a messed up hole on the auger.
I took the blower off and put the blade back on so I could get drives done....
Thanks in advance for your advice!!!!!
   / auger damaged when shear pin sheared on front mounted blower for Cub Cadet 3235 #2
If it wasn't to bad I would clean up the holes and give that a try before drilling new hole . The auger only turns one way so when pressure is applied to the shear bolt it isn't as though it will work back and forth . I have found that putting a load on the blower slowly at first prevents me from breaking a shear bolt .
   / auger damaged when shear pin sheared on front mounted blower for Cub Cadet 3235 #3
Avoid drilling more holes if you can -- they will potential weaken the shaft(s). I would not be worried about a mildly wallowed out hole for a shear pin.
   / auger damaged when shear pin sheared on front mounted blower for Cub Cadet 3235 #4
I would drive out the old pin, and install the new one... If the new pin goes right in, I wouldn't do any "cleaning up".
SR
   / auger damaged when shear pin sheared on front mounted blower for Cub Cadet 3235 #5
The oval will not hurt anything. Put a new bolt in and quit overthinking it.
   / auger damaged when shear pin sheared on front mounted blower for Cub Cadet 3235 #6
Welcome from coastal SC, some pic's would be helpful
2025 GPS Trailer (A56857)
2025 GPS Trailer...
2016 Lincoln Navigator SUV (A59231)
2016 Lincoln...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
KBH Tank Trailer (A61307)
KBH Tank Trailer...
2019 BOBCAT E45 EXCAVATOR (A59823)
2019 BOBCAT E45...
