atv not idleing right
   / atv not idleing right #11
sal64 said:
thanks all, i will take carb off and clean it, i cleaned it once before about 7 yrs ago. was hoping i wouldnt have to the atv is so old if i break or loose a part mite not be able to get a new one.
I would not worry about replacement parts for a Honda. I would guess you can get any replacement part you may need.
Is it a 200 Big Red? If so I still have one and it's just a matter of sailing the carb overnight after you take it apart. Then blow all the jets out with carb cleaner and be careful not to break the rubber gasket. They still make rebuild kits for it that you can find online. Also make sure your tank isn't rusting. You may need to install a fuel filter if so. They also make plastic tanks to fit the model.
no its not a big red its a sx350 4x4,
   / atv not idleing right #13
Pour about 4 ounces of sea foam in the gas tank and it will probably clean out the gunk out of the carb and run right. That's what I did for my 4 wheeler and I had no more problems. It also works on chainsaws too.
i will have to try that tu.
UNUSED X-STAR 101" X 25' BRIDGE PLATFORM (A51243)
UNUSED X-STAR 101"...
2013 Mack GU713 T/A Vac-Con Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
BUNDLE FENCE PIPE (A51244)
BUNDLE FENCE PIPE...
UNUSED JCT SKID STEER QUICK ATTACH 72" TILLER (A51244)
UNUSED JCT SKID...
2015 CATERPILLAR D9T HI TRACK CRAWLER DOZER (A51242)
2015 CATERPILLAR...
Skid Steer Gravel Leveler (A50515)
Skid Steer Gravel...
