ATV Grader
/ ATV Grader #1
Wynnefraser
Melbourne, Australia
I have been working on a grader for behind the ATV but have run into a few problems, I originally planned to use electric car jack to lift and lower the blade but once I got a look at them they looked pretty weak(as in the materials they were made with) I have also look at using electric winch but the blade would swing free and there would be no down force. I also need to add more supports but that will happen along the way
I have finally decided to use hydraulic. The two options I have looked at are electric over hydraulic or a petrol motor hooked upto a hydraulic pump. I definetly like the idea of electric over hydraulic but all the products I have found would use more amp power than the ATV would generate. Using hyrdaulic would also support future projects for the ATV such as a backhoe etc...
For a look at what has been build to-date...
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1319-1.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1318-1.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1317-1.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1316-1.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1315-1.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1318.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1319.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1311-1.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1312-1.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1313-1.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1314-1.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1317.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1316.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1315.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1314.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1313.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1312.jpg
http://i85.photobucket.com/albums/k43/wynnefraser/20-10-06_1311.jpg
(This has also been posted on Machine Builders Network)
/ ATV Grader #2
Have you considered a linear actuator to raise and lower the blade? They are stronger that you might think. I had one on my JD Gator's dump bed and now on my Polaris Ranger and they never failed to dump a full load. I know you mentioned future projects such as a back hoe, but I think the actuator is a very viable solution. Check ebay, there are tons of them there.
/ ATV Grader
"I have looked at linear actuators but thought that they would be too weak. There would be a hugh amount of side preasure generated by the way the blade is mounted and if the thread got bent then thats the end of it, it would need to be replaced."
I just looked up actuators again and found this website Nook Industries - Manufacturing Linear Actuators for the Motion Control Industry - Ball Screws, Lead Screws, Slide Systems, Screw Jacks and Electric Cylinders., they have 12 volt, 1500lbs dynamic load rating. It would require two, so there is a combined rating of 3000lbs. Should be more than enought, just depends on cost and the reply I get from emailing them.
/ ATV Grader #4
These pictures remind me of the time that i was 13 and had a long boring school holiday. I split my pedal go kart in half, welded an extension in the frame because i grew too tall for it, and also welded a hand lever acting 3 point hitch for it, first implement was a field drag because it was so easy to weld up, but the second piece of equipment was a 3pt hitch dirt scoop.
Few weeks later i changed the frame again, my 3pt lift lifted about 120 kg so i had to ballast the front with one or two concrete manure pit bricks. Result was that the frame bent so i reinforced it again.
Too bad i dont have pictures of my 3pt and bucket setup..
Electrical actuators lifting 1000 kg from Linak Denmark, cost 480 Euro, without a controller or anyting.
If it was my project, i'd save my money for a real tractor, and also save my ATV from any undue stress which in the end saves even more money
/ ATV Grader #5
I am not intending to knock your invention. Before I had a tractor, I made a very simple grader that worked pretty well on my ATV. I took a 6 foot wide piece of scrap steel that was about 14 inches deep with a 4 inch lip on it. I welded 2 -2 foot long rebar loops on each end to attach a pull chain. I then ran the chain to a chain hook mounted to my ATV hitch. I was amazed at how well it worked for being so simple of a design. I could tilt it one way or the other by moving the chain location on the hitch. I used it on the 1 mile of Forest Service access road that leads to my remote property and it made a substantial difference in smoothing out the bumps and ruts.
/ ATV Grader #6
Is there any objection to placing an 8 inch trailer tire ahead of the blade that just clears the ground in the "UP" position while grading and raises the blade 4 inches in the "DOWN" position ? That tire could swivel and be raised and lowered with a simple electric mechanism-perhaps an electric car window motor.
WOLVERINE PT-16-01C 3PT HITCH ADAPTER (A60432)
WOLVERINE...
2017 Dodge Charger Sedan (A59231)
2017 Dodge Charger...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
UNUSED FUTURE FT15 EXCAVATOR (A60430)
UNUSED FUTURE FT15...
3 BOTTOM TURN PLOW (A60430)
3 BOTTOM TURN PLOW...
