Atv drawn flail mower
   / Atv drawn flail mower #1
dieseldoc25
Luray, VA
Ford 8N and 1970 Deere 4020
Good evening all,
Just wondering if anyone has one of these things. Pow-r-kraft atv drawn flail mower. I bought one on a whim ($1695 shipped to me in Virginia from Oregon). The next closest is a good bit more expensive.
I bought a 59 inch cut and it is powered by a knock off Honda engine.
Anyone have one? Anything I should plan on upgrading? I am going to use it behind my 3010 diesel mule. I have a 44 inch swisher rotary I use for my small mowing now as well as a 60 inch swisher finish mower. I am going to replace both with this. I have a zero turn for my lawn and a 10 foot schulte rotary for the big mowing. Just need something small for our walking trails and such around the property.
Thanks!
59? Gas Flail Mower, PK-AT145E | eBay
   / Atv drawn flail mower #2
I bought an Alamo fail mower, commercial grade, with the Honda red engine. The first thing I found was that the 12" wheels were way too small for field or trail work. It appears to be designed for mowing parks and ball fields. So I put on some much bigger go cart wheels to raise it up a bit. But the front lip still would catch on clumps of grass and cause it to flip over. So we put a ball-type hitch and reinforced the tow arms. Still would catch and flip, spilling gas and catching fire [to itself and the grass] all while the 80 chain knives kept whirling -- not a good situation. I never even made it to a real trail because it was obviously not going to work.
The other thing I found was that it is very hard to hold an ATV at a steady pace. Turing corners or starting up a hill it would bog down [Honda 450 ES] and when you added more throttle it would zoom ahead. and its not a comfortable as a tractor or even lawn tractor since there is no back to lean on.
I hope you have better luck but I had to conclude that ATVs aren't tractors and mowing is for mowers.
   / Atv drawn flail mower #3
I would look hard at adding another 2-3 feet to the tongue of it, otherwise it will be almost impossible to back up...
Aaron Z
IH 1066 Tractor (A50514)
IH 1066 Tractor...
2022 Polaris General 1000XP UTV (A50514)
2022 Polaris...
Behlen Country 3 pt Leveler (A50514)
Behlen Country 3...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
Wolverine Mini Skid Steer Stump Grapple (A50515)
Wolverine Mini...
