Attic insulation - Questions..
   / Attic insulation - Questions.. #11
</font><font color="blue" class="small">( Do you need to worry about your soffit vents? )</font>
Yes. We stapled the covers to the roof sheathing. The are just styrofoam channels about 4' long.
   / Attic insulation - Questions.. #12
Bird, that sounds about right for the average attic. Our two man crews were expected to do three a day.
You know how hard you worked keeping up with one machine. When we did whole house new construction we had three machines running. Two supplying hoses to two inch holes drilled in the side walls and one to the attic wide open. The machines were all in a 24 foot van truck that carried all the tools and repair parts. We could fix most things that would go wrong. It was a five man crew and I would hire guys right out of the service. Uncle Sam trained them to work well together.
One man supplied all three machines and monitored three radios to the nozzle men. Not easy to do when you only have two ears. The fifth member of the crew tried to cut the holes in the walls ahead of the nozzles filling the wall cavities. He also had to help the loader once in a while by moving bales closer to the machines from the supply truck. The guys would rotate the jobs during the day. They were paid by the cubic foot of the job so they loved those big expensive houses all in the same tract.
Good men, good work and plenty of jobs to make a living for all.
Tim
   / Attic insulation - Questions.. #13
Rogue,
You may already know this but there are "covers" that slip
between the rafters to hold the insulation. They prevent the
insulation from blocking the soffets. I think I just saw some
covers to put on top off recessed fixtures but you would have to
check those out very carefully.
Later,
Dan McCarty
   / Attic insulation - Questions.. #14
If you get the chance, pick up this months issue of Fine Homebuilding (December 03/January 04). It is an eye opener for insulation. Great article on cellulose vs fiberglass etc. Rat...
I'll try and find it! Which way did it lean?
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2007 FREIGHTLINER...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
New/Unused Forklift Jib (A57453)
New/Unused...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
1974 Ford F600 Grain Truck (A56436)
1974 Ford F600...
