Oil & Fuel Attention: 3510/4110 Fuel Leak
   / Attention: 3510/4110 Fuel Leak #1
GIJOE
Baton Rouge, La.
MAHINDRA 3510 w/ ML112 FEL
Those of you that own a 3510 and possibly a 4110 need to check the fuel line that runs from the fuel pump to the injector pump on the right side of the engine. It is a 5/16" ID rubber, single layer fuel line about 6"-8" long that attaches to the injector pump next to the injector pump bleed valve. Mine developed a leak today while mowing and saturated the right side of the engine with diesel fuel. I smelled a very strong fuel odor and noticed a haze of smoke coming from under the hood. There was no other indication of a fuel problem (missing or stalling). I was lucky it didn't catch fire and was glad the exhaust manifold was on the other side of the engine. I replaced the hose with a nylon reinforced double layer fuel line and was up and running in about fifteen minutes. It is a very easy fix and I hope the worst doesn't happen to someone else's machine.
Joe
   / Attention: 3510/4110 Fuel Leak #2
I hope you have a fire extinguisher mounted on your rig. Some folks have two of them. It is cheap insurance.
   / Attention: 3510/4110 Fuel Leak #3
Proably something we should keep an eye on. Mine did the very same thing. I just wrote it off as a freak occurance but now that it has happened to another member here, it does make you wonder. If I remember correctly, I think there is another fuel line there also. I think I will replace it as well.
   / Attention: 3510/4110 Fuel Leak #4
That's really strange, the same thing happened to my 3510 this past weekend. Seems that it may be a problem. It did make a mess, but no harm done. The extinguisher is good insurance.
   / Attention: 3510/4110 Fuel Leak #5
Thanks very much for the tip GIJOE! I'll check my 3510 today.
Rusty
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
3 Point Metal 4ft Cargo Carry (A51573)
3 Point Metal 4ft...
UNUSED TOPCAT 81" HYD HEAVY DUTY HYD BRUSH CUTTER (A51248)
UNUSED TOPCAT 81"...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2018 RoGator 1100C (A53472)
2018 RoGator 1100C...
