Oil & Fuel Attention: 3510/4110 Fuel Leak
   / Attention: 3510/4110 Fuel Leak #1
GIJOE
Baton Rouge, La.
MAHINDRA 3510 w/ ML112 FEL
Those of you that own a 3510 and possibly a 4110 need to check the fuel line that runs from the fuel pump to the injector pump on the right side of the engine. It is a 5/16" ID rubber, single layer fuel line about 6"-8" long that attaches to the injector pump next to the injector pump bleed valve. Mine developed a leak today while mowing and saturated the right side of the engine with diesel fuel. I smelled a very strong fuel odor and noticed a haze of smoke coming from under the hood. There was no other indication of a fuel problem (missing or stalling). I was lucky it didn't catch fire and was glad the exhaust manifold was on the other side of the engine. I replaced the hose with a nylon reinforced double layer fuel line and was up and running in about fifteen minutes. It is a very easy fix and I hope the worst doesn't happen to someone else's machine.
Joe
   / Attention: 3510/4110 Fuel Leak #2
I hope you have a fire extinguisher mounted on your rig. Some folks have two of them. It is cheap insurance.
   / Attention: 3510/4110 Fuel Leak #3
Proably something we should keep an eye on. Mine did the very same thing. I just wrote it off as a freak occurance but now that it has happened to another member here, it does make you wonder. If I remember correctly, I think there is another fuel line there also. I think I will replace it as well.
   / Attention: 3510/4110 Fuel Leak #4
That's really strange, the same thing happened to my 3510 this past weekend. Seems that it may be a problem. It did make a mess, but no harm done. The extinguisher is good insurance.
   / Attention: 3510/4110 Fuel Leak #5
Thanks very much for the tip GIJOE! I'll check my 3510 today.
Rusty
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
Lift Gate (A52377)
Lift Gate (A52377)
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52576)
2015 VOLVO VNL...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
